Solar lighting
8 replies to this topic
#1 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted September 01, 2011 - 08:12 AM
I want to add some solar powered lights for accent around my home. I know you get what you pay for, so I am looking for something that is of at least the quality to last 5 years or so. Any brands come to mind that should be on the short list? Any to stay away from?
Thanks in advance.
#2 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted September 01, 2011 - 10:52 AM
I am sure the solar lighting that is available now is much better then what we had 10 years ago. I haven't had any since then but the ones we did have back then only lasted through the summer/fall and then after winter they didn't work anymore. I think technically you should pull them out in the winter and put em in storage due to the cold weather killing the batteries.
#3 Alc ONLINE
  • 6,917 Thanks
  • 7,474 posts
Posted September 01, 2011 - 11:56 AM
The newer solar lights seem to have gone to LED which stay lit a lot longer . My wife bought cheap ones just to mark the driveway and I was surprised how well they work for the price , around $3 each . Maybe check to see if the batteries are replaceable if your spending $$$ for them , Al
#4 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted October 12, 2011 - 10:34 PM
bought several two years ago for Menards on clearance for under $2 each they have been outside all this time and no problems
#5 mjodrey OFFLINE
  • 2,356 Thanks
Posted February 24, 2012 - 10:32 AM
Yeah,those LED ones are great.
#6 daytime dave OFFLINE
  • 4,845 Thanks
  • 6,545 posts
Posted February 24, 2012 - 11:50 AM
I have purchased some last year. I got some at Lowes and some at Walmart. If you buy the better grade led, you will see a difference. The only down side I have seen is if you mix and match, you can see the difference. I use mine in back, in the garden, so it doesn't matter.
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 15, 2012 - 08:02 AM
We've got a couple of the spotlight type that you stick in the ground. They have the little solar panel on the top about 3"x4". The brand is Moonrays and they have a website. I was sceptical that these would work but they did fine all summer/fall. I take them in for the winter because they get buried or destroyed when I plow. I put them in the windows of the house on the South side in areas where we could use a night light. They worked well and even on the short days of December there was still light from them at dawn.
I haven't had good luck with the ones that look like little lanterns. The water gets into them and they stop charging. We lost about 1/2 of them. If you take them inside and clean them every fall then they might work fine. I don't think it's good for the batteries to sit for long periods in a discharged state.
I notice that the hardware on the Moonrays lights is Stainless steel which is a good indicator that they were built with a bit of thought to lasting in an outdoor environment. Many of the others we bought have rusted and look terrible. I think the bottom line is to spend a bit more for something that's better made.
#8 grnspot110 ONLINE
grnspot110
  • 4,162 Thanks
  • 2,649 posts
Posted March 15, 2012 - 11:46 AM
My problem was finding "low-voltage" lights! We needed 4-12V to put by the front step, against the north side of the house where I wouldn't expect to get enough sunlight for solars. Finally found a set of ten lights at Home Depot (on sale, so they probably won't have any more). Otherwise, I would have to piece the parts! ~~ Lowell
#9 mjodrey OFFLINE
  • 2,356 Thanks
Posted March 17, 2012 - 04:58 AM
Glad you found what you were looking for,Lowell.
