now i have a real CC - 109 with hydraulic lift
9 replies to this topic
#1 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted August 31, 2011 - 11:20 PM
I just brought home a cub cadet. I've been trying to buy one for a while.
Needs work. The PO bought a new regulator that has not been installed. The wiring (all 4 wires) look messed up.
It did start and run well enough to drive itself onto the trailer.
A bit of smoke from the motor, but could be due to the 2yr old gas.
Has hydraulic lift.
Mower deck is ruff. One of the spindles has some play in it.
The snow thrower looks old and solid but does not appear to have been used a lot.
It's missing the linkage between the PTO lever and the mechanical PTO. Not sure what the missing parts look like. Is it easy to convert this PTO to electric?
Will get pictures at another date, but here are the pictures from the ad:
#2 Sergeant OFFLINE
Sergeant
  • 46 Thanks
  • 136 posts
Posted August 31, 2011 - 11:29 PM
Nice Looking 109 except for the Deere seat:thumbs:
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted August 31, 2011 - 11:36 PM
GREAT find! My trim/small area mower is a 109 and I really like it. The rod for the PTO clutch is just a simple rod with a 90 degree bend on one end and a threaded turnbuckle on the other end for adjustment. I wouldn't change to an electric clutch because they are expensive and the manual clutches work great and last forever with very minimal maintenance.
#4 mjodrey OFFLINE
Posted September 01, 2011 - 04:23 AM
Yes that JD seat has to go,but other than that,it looks pretty good.
#5 KennyP ONLINE
  • 38,243 Thanks
  • 45,876 posts
Posted September 01, 2011 - 04:33 AM
Nice 109! There isn't a way to mount an electric PTO to these.S/G pulley is in the way. For the PTO linkage, I got a screen door brace with the turnbuckle in the middle and used it.
Here is a color wiring diagram in case you need it.
I hope the new regulator is the correct one, there are several different types.
  • NUTNDUN, MH81, motobreeder and 1 other said thanks
#6 MH81 OFFLINE
Posted September 01, 2011 - 07:15 AM
Nice Cub. Thanks for sharing the pics.
#7 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted September 01, 2011 - 10:54 AM
Nice Cub. Guys already quick to respond on the pto linkage. Easy to make. Congrats on the new to you machine.
#8 Cvans OFFLINE
  • 6,636 Thanks
  • 6,125 posts
Posted September 01, 2011 - 11:20 AM
Nice looking tractor. I wish we lived closer as I have 2 very nice decks of which you could have your pick. They are off of a 129 and a 127. Too nice to go to the Iron pile.
#9 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted September 01, 2011 - 12:09 PM
The PTO is incredably easy to adjust. when you do get the turn buckle and the rods remember that when the lever pushes the button on the clutch in its disengaged and when its the lever is off the clutch its ingaged. Once thats done its nice and you just throw the lever forward and away it goes. No instintanious thing like an electric clutch. I think those put to much stress on every thing.
#10 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted September 01, 2011 - 12:25 PM
Nice Cub, and I agree, the JD seat is screaming to come off!
Enjoy your 109. I have a 123 and really like it!
