Does painting a Ford 120 with New Holland Blue hurt the value?
12 replies to this topic
#1 joshtiffany OFFLINE
joshtiffany
  • 3 Thanks
  • 23 posts
Posted August 31, 2011 - 10:13 AM
Does painting a Ford 120 with New Holland Blue hurt the value, if I resell?
-JT
#2 olcowhand OFFLINE
  • 43,120 Thanks
  • 31,998 posts
Posted August 31, 2011 - 10:36 AM
I wouldn't think so at all. It is a real close color as far as I'm concerned.
  • joshtiffany said thank you
#3 KennyP ONLINE
  • 41,453 Thanks
  • 47,382 posts
Posted August 31, 2011 - 04:19 PM
Josh, I don't think it would hurt a bit. There are a few who will differ, but if it isn't a 'restored' tractor, who cares. As long as it is a good paint job and keeps the rust a bay, go for it.
#4 joshtiffany OFFLINE
joshtiffany
  • 3 Thanks
  • 23 posts
Posted August 31, 2011 - 04:36 PM
Much Obliged!
#5 joshtiffany OFFLINE
joshtiffany
  • 3 Thanks
  • 23 posts
Posted August 31, 2011 - 04:38 PM
Thanks, do you recommend a clear coat on top of? Also, I want to paint the K301, do I need to use high temp engine enamel, or will the stock NH work?
#6 joshtiffany OFFLINE
joshtiffany
  • 3 Thanks
  • 23 posts
Posted August 31, 2011 - 04:40 PM
#7 KennyP ONLINE
  • 41,453 Thanks
  • 47,382 posts
Posted August 31, 2011 - 04:54 PM
Josh, I do not know what skill as a painter nor equipment you have. A clear coat would be beneficial. I'm hoping others who have more experience with painting will chime in. As far as the engine, that will depend on what color you want it to be. Most weren't painted with high temp when they left the factory.
#8 poncho62 OFFLINE
poncho62
  • 2,230 Thanks
  • 1,828 posts
Posted August 31, 2011 - 07:00 PM
As long as you dont paint it green.........lol
If you really want it right, take a piece to an auto paint store and get it matched with an auto paint
#9 joshtiffany OFFLINE
joshtiffany
  • 3 Thanks
  • 23 posts
Posted September 01, 2011 - 06:24 AM
lol
#10 joshtiffany OFFLINE
joshtiffany
  • 3 Thanks
  • 23 posts
Posted September 01, 2011 - 06:26 AM
I am blessed/cursed with an insatiable desire to be self sufficient and that includes painting. I am a rookie but getting better. If the high temp is not needed, than I will go with the same all over...Thanks, JT
#11 mjodrey OFFLINE
Posted September 01, 2011 - 07:21 AM
New Holland blue is noticeably different than Ford blue when compared side by side.But it is a close color.
Also,you shouldn't need high heat paint,although it may discolor around the exhaust.
#12 Buck OFFLINE
Buck
  • 36 Thanks
  • 116 posts
Posted September 06, 2011 - 05:56 PM
I think Home Depot sells in their paint section the implement paint in spray can form. I think if I remember right they have Ford Blue. You could use this or paint a sample board and then bring that to automotive paint parts store. They could match it for you and you could run it through your own/rented paint equipment. Think about the resell and who that would be. Chances are if it was a tractor guy he might do it over anyway or if it were a homeowner, they might not care.
#13 ford maverickdude OFFLINE
ford maverickdude
  • 2 Thanks
  • 18 posts
Posted October 14, 2011 - 01:36 PM
No it shouldn't but New H is darker the ford blue.
