317 serial location(s)
5 replies to this topic
#1 PEIslander OFFLINE
PEIslander
  • 5 posts
Posted August 30, 2011 - 02:41 PM
The chrome-like sticker under the steering wheel on my 317 has been partial damaged - perhaps by a passing boot. What I can read says:
C317L
211???? M
317 Tractor
Is there any other location on the unit, where I could look, where the serial number may be more permanently stamped?
Thanks,
Ron Curtis
  • 14,862 Thanks
  • 15,511 posts
Posted August 30, 2011 - 02:51 PM
That is the only location for the tractor I.D. You have enough for the year I.D. and any parts you might need.
#3 JDBrian OFFLINE
  • 9,628 Thanks
  • 14,152 posts
Posted August 30, 2011 - 03:38 PM
PEIslander, it looks like a ser. No. starting with 211 would be 1982. The parts diagrams on jdparts.com have information on any parts changes related to ser. no.
#4 JDBrian OFFLINE
  • 9,628 Thanks
  • 14,152 posts
Posted August 30, 2011 - 03:39 PM
Just a thought. The engine ser. no. should tell you something as well. I'm sure someone here knows how to decipher the numbers on the twins.
#5 allenblakee OFFLINE
allenblakee
  • 12 posts
Posted August 31, 2011 - 11:40 AM
You have to watch out using the engine to ID the tractor as the Kholer I was a bad engine and frequently was replaced by the II. My 317 is an example of this. So the tractor year and the engine year are completely different. However if the engine series is less than 24300 then you may have the original still.
#6 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted August 31, 2011 - 11:56 AM
Here's a little help when identifying year by type code (works for 1975 to 1982 tractors)
FYI. On the 1975 to 1982 tractors, it was pretty easy to find the year of John Deere tractors as it was in the model number. The model number usually had a C then the model of tractor, i.e. "317" then another letter which represented the year. If the 5th character was a "D", then it was a 1975, a "E" - 1976, "F" - 1977, "G" - 1978, "H" - 1979, "J" - 1980, "K" - 1981, and a "L" was a 1982. So C317L was a 1982 317.
1975 - D
1976 - E
1977 - F
1978 - G
1979 - H
1980 - J
1981 - K
1982 - L
In 1983, Deere stopped that practice and started putting "M" on the beginning and included a couple of "0" followed by the model number and then an "X". So a 318 was M00318X and the only way to tell the model year was by the serial number itself.
  • PEIslander and Trav1s have said thanks
