electrolysis tank
6 replies to this topic
#1 drbish OFFLINE
drbish
    Collecter
  • 1627 Thanks
  • 1412 posts
Posted August 29, 2011 - 07:03 PM
got this from where i workgoing to hook it up probably first of next month,had somebody to sand blast but going to attempt this myself,with all the no how i got from gt talk ,should get the whole frame immersed at once Piedmont Bait Tanks - 1800 Series
#2 JDBrian OFFLINE
  • 9681 Thanks
  • 14162 posts
Posted August 29, 2011 - 07:13 PM
That would make a nice tank and could take a whole frame easy. I have found that for parts that have complex shapes you will sometimes have to make up a temporary anode and suspend it so that you can get current flowing in hard to get at areas. It is line of sight, so if the anode can't see a hidden part of the frame then the rust and paint will not come off. Let us know how it works out for you. I find it's a big work saver as long as you aren't in too big a hurry because it seems to work best if left to cook for 24hrs.
#3 NUTNDUN OFFLINE
  • 10454 Thanks
  • 15622 posts
Posted August 29, 2011 - 07:20 PM
Would definitely be a good tank to use, not real high and a lot of water area which will help eliminate some of the line of sight effects. I am switching our anodes from rebar to flat stock steel on the next redo of the rebar cage. Will make cleaning off the anodes a lot easier.
#4 KennyP ONLINE
  • 52540 Thanks
  • 53104 posts
Posted August 29, 2011 - 07:51 PM
Nice looking tank. Will you have to reinforce the long sides so they don't bulge out?
#5 drbish OFFLINE
drbish
    Collecter
  • 1627 Thanks
  • 1412 posts
Posted September 01, 2011 - 05:22 PM
no i should not have to reinforce the tank it is built to hold water with the sides already reinforced with half round cardboard and sprayed with fiberglass
#6 KennyP ONLINE
  • 52540 Thanks
  • 53104 posts
Posted September 01, 2011 - 06:00 PM
Thanks, kind of hard to tell from the pics. Should be a great tank.
#7 mac102004 OFFLINE
mac102004
  • 609 Thanks
  • 613 posts
Posted September 01, 2011 - 08:31 PM
You could pretty near use that for a swimming pool. 280 gallons! lol You'll probably need a good sized charger for best results.
