Well, I got ALOT acomplished today. I took apart the
PTO clutch and pounded the bearing out. I then put it in a vise (not to tight though) and tried to work it back and forth with a pair of pliers. That didnt work, so I grabed a jug of rotella 40w oil and pours some of it in a bowl. I then put the bearing in the bowl and let it sit for an hour while I messed with the wiring. I took the bearing out and repeated the first step I took and finally got it to move smoothly. I put the clutch back together, while the bearing was soaking in the oil I took the selonoid out of the tractor which did turn out to be faulty. I grabed one from another junk mower I got and put that in there. It just clicked. So, I went a grabed another one from a different mower and put the in there is wella, it works. But it still doesnt charge (still gotta work on that. I put the clutch on the tractor and got it all dialed in. So, having the main tractor in semi working order I went on to the mower deck. The front roller was really loose and floped around and hit the deck when I moved it. So I brought out the welder and welded some washers to it and now the roller is smooth. I chose a deck hanger that was in good working order and put it and the deck under the tractor (that took a few trys haha). I also have yet to put tubes in the original tires. there is one picture of the machine I use to change tires
Now everything on this tractor works.
sept the charging system
PS I did get some video of me welding and I will post that once I get off my lazy arse and edit and post it
