is this a descent deal
12 replies to this topic
#1 Trent Thomson OFFLINE
Trent Thomson
  • 208 Thanks
  • 238 posts
Posted August 27, 2011 - 07:51 PM
David bradley tractor QUEENS COUNTY, PEI
#2 NUTNDUN OFFLINE
  • 10455 Thanks
  • 15622 posts
Posted August 27, 2011 - 07:54 PM
I would probably go around $150 to $200 on it. Not saying his asking price is too high though. One thing going wrong with it is that it doesn't have the hood. Has the wheel weights though and the cultivator looks to be in good shape.
#3 Trent Thomson OFFLINE
Trent Thomson
  • 208 Thanks
  • 238 posts
Posted August 27, 2011 - 07:59 PM
Good to know. I would never have known that there ever was a hood
#4 NUTNDUN OFFLINE
  • 10455 Thanks
  • 15622 posts
Posted August 27, 2011 - 08:03 PM
They look sweet with the hood. You can find hoods fairly easily at tractor shows or auctions. Let me dig through my pics I know I have a pic with one with a hood.
#5 NUTNDUN OFFLINE
  • 10455 Thanks
  • 15622 posts
Posted August 27, 2011 - 08:05 PM
Yep found one.
This one has the hood up but you get the idea of what the hood looks like.
#6 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted August 27, 2011 - 09:49 PM
Some of them came without. I believe they had the Clinton engines and were very basic.
Almost sure that is a replacement engine.
#7 davbradtrac OFFLINE
davbradtrac
  • 4 posts
Posted August 28, 2011 - 07:36 AM
Also has the wrong tank on it dbs all had the cap in center. They did have several models without hoods they were either briggs or wisconsin powered except the every last model which had a tecumseh
#8 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted August 28, 2011 - 08:59 AM
Thanks for the correction, it thought the non hood ones were Clinton powered.
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3484 Thanks
  • 2816 posts
Posted August 28, 2011 - 09:13 AM
At no time did DB ever use a clinton engine. You see alot of them with it, but thier not factory.
The first thing one needs to know about a DB tractor is what model its. There are about 29 differnt models(46-67) of the walking tractors and 21 in the riding ones(58-65) also there are several differnt color groups used over the yrs. By having the model, you can then tell whether it had a hood, what the color would be, what the engine would be, and what features it had, like reverse, slow speed, vari-speed. DB's are the most generic tractor built, as everyone who see a walk-behind seems to think it a DB one.
Looking at the one in the picture, i see a good pair of weight worth about $50, a vator(probally a 524) worth about $30, and a main frame with a wrong engine worth about $25-$50. We'ed need to knowthe wheel size,as 15" are worth a lot more than 16" ones. If one offered $100 you might have a good start to a tractor, again it all depends on what the model is.
#10 davbradtrac OFFLINE
davbradtrac
  • 4 posts
Posted August 28, 2011 - 03:50 PM
From the pics there 16" wheels (gap between weight and bead) the weights are 15" as the holes are slotted for 15 or 16" wheels. 16" weights are not slotted as they will only fit 16" wheels
#11 davbradtrac OFFLINE
davbradtrac
  • 4 posts
Posted August 28, 2011 - 03:54 PM
Jeff you break tractors down like I do this worth this much etc. I do that unless its a super nice original
#12 JDBrian OFFLINE
  • 9681 Thanks
  • 14162 posts
Posted August 28, 2011 - 04:00 PM
Yep found one.
George, that saw blade looks like a real widow maker!
#13 tractorman604 OFFLINE
tractorman604
  • 269 Thanks
  • 694 posts
Posted October 06, 2011 - 08:28 AM
I agree, but i sure would love to own that setup.
