* * * * * 1 votes
1971 120
612 replies to this topic
#121 KennyP ONLINE
  • 40,116 Thanks
  • 46,761 posts
Posted June 05, 2012 - 07:26 AM
I spent some time on JD Parts and found that the 314 uses 1" spindles and the part cross-ref-ed to late 140, 300, 312, 314, and 316k . The 120/140 share the same size. Do you have any pics? I can compare to the original and replacement spindles from my 120.
I'll see about getting some pics.
#122 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 05, 2012 - 06:33 PM
Did a bit of work this afternoon in an attempt to avoid stuff at the church :smilewink:
Primed
Blitz black!
#123 JDBrian OFFLINE
  • 9,642 Thanks
  • 14,157 posts
Posted June 05, 2012 - 07:22 PM
You are doing a great job on the 120. It's a pile of work restoring one of these old tractors but worth the effort IMO. I vote that you should remove everything and paint the frame now that you are this far into it.
  • Trav1s said thank you
#124 KennyP ONLINE
  • 40,116 Thanks
  • 46,761 posts
Posted June 06, 2012 - 04:29 AM
Since you are that close on the tear down, might as well do the frame.
#125 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 06, 2012 - 07:26 AM
The masses have spoken and I must honor their voices!
#126 KennyP ONLINE
  • 40,116 Thanks
  • 46,761 posts
Posted June 06, 2012 - 07:47 AM
I got pics of the spindles finally. They can be found here:
http://gardentractor...13969-spindles/
Hope all goes well with the rest of the teardown!
#127 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 06, 2012 - 08:22 AM
Posted in that thread. Definitely different than either pair I have for the 120 and light years different from the RF stuff I am familiar with.
#128 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 08, 2012 - 07:18 PM
Just picked up a solid 41 deck in Kansas!!! One step closer to putting it back to work.
#129 JDBrian OFFLINE
  • 9,642 Thanks
  • 14,157 posts
Posted June 08, 2012 - 07:24 PM
Keep us posted. We don't see that many 120 restorations!
#130 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 09, 2012 - 07:04 AM
Also got h2 parts for it. Can't wait to do more to it.
#131 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 09, 2012 - 06:38 PM
Here are a few pics of the items I picked up for the 120.
H-2 parts from a 316k. I know they are not "correct" but it is a worker that I plan to enjoy.
Here is the deck that I picked up for it. It is another Model 41 (38" cut) from the same 316K. It is solid but needs straightened out. I think "the blue wrench" and a bit of hammer lovins it will be fine. At this point it is a solid worker and fits my needs just fine. Again, this is a worker and not a show machine.
The gauge wheel on the left of this picture was welded at one time and is a bit off but that was not a deal-breaker. Again, this will go on a worker and not a show machine.
#132 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 09, 2012 - 06:41 PM
You don't see many because there were not that many 120's made. From the serial numbers on the WFM registry there appear to have been less than 10,000 made. One might call this a rest-ification as I am adding non-factory installed items and it will likely get a re-power some time. I won't be doing much during the next week with a crazy schedule at the church --> Community VBS with 150+ kids every morning and the normal stuff the rest of the week. I am tired just thinking about it. :sleep:
Edited by Trav1s, June 09, 2012 - 06:44 PM.
#133 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 17, 2012 - 08:25 AM
Another quick update:
I finished painting the black parts I started last week and wiped out my can of Blitz black. Fortunately I did not run out. I also got the seat pan back from the local welder. He did a nice job welding up the holes where the cab was once mounted. I was a bit surprised to see he used some spot putty to smooth them then put a coat of paint on the entire seat pan. The problem is that he did not sand/prep the old paint before painting the new. When I hit it with wet 320 grit, the new paint started to peel off very easily. I hope to get it all sanded and primed in the next day or two.
#134 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 18, 2012 - 01:32 PM
Found Carlisle All Trail 23x8.00-12 Lawn Mower Garden Tractor Tires on eBay but not on Millertire.com. I am close to pulling the trigger on them for the rear of the 120.
In light of the incedent this morning involving the 110 I pulled the trigger on these. Miller Tire is shipping them tomorrow. Now I need to get to work on the rear wheels and keep going on the rest of the tractor.
Edited by Trav1s, June 18, 2012 - 01:32 PM.
#135 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted June 22, 2012 - 09:46 PM
Tires arrived today!!!
