* * * * * 1 votes
1971 120
612 replies to this topic
#106 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted May 13, 2012 - 09:09 PM
I hope to install valve stems and inflate the front tires tomorrow. At this point I am going to remove the front axle to clean it up for repaint. While it is out I will attack the sloppy steering too.
#107 Texas Deere and Horse OFFLINE
  • 14,866 Thanks
  • 15,512 posts
Posted May 13, 2012 - 09:43 PM
Travis, The 120 is coming along very nicely. You are doing a great job. Those front wheels look great !! :thumbs:
#108 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted May 13, 2012 - 09:45 PM
Thanks! I hope the rest of the tractor looks as good those wheels which turned out pretty good for a spray can. The Valspar paints are pretty easy to work with.
Edited by Trav1s, May 13, 2012 - 10:01 PM.
#109 KennyP ONLINE
  • 40,238 Thanks
  • 46,811 posts
Posted May 14, 2012 - 05:52 AM
That's looking good! Does the 120 have 1" spindles?
#110 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted May 14, 2012 - 06:43 AM
I believe they are 3/4" which is the same as the 300/312/314/316k/317. I will get a pic of the damaged one to show the diff.
#111 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted May 14, 2012 - 09:55 AM
Ran to Napa and picked up metal valve stems for the tires. :laughingteeth:
#112 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted May 14, 2012 - 10:15 AM
300 series are 1" spindles. I'm not sure if the 120 is or not.
  • Trav1s said thank you
#113 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted May 14, 2012 - 10:37 AM
120's have 3/4" spindles.
#114 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted May 14, 2012 - 11:04 AM
<---- clueless 120 owner :smilewink:
#115 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted May 14, 2012 - 04:35 PM
#116 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted May 30, 2012 - 04:43 PM
Back from the dead :smilewink:
I have done a bit more work since the last post including:
Assembled the newly painted spindles and tires with new bearings and races. Those dust caps are a pain :mad2:
I also removed the front axle to clean and repaint next week. I will order new ball joints from Deere next week. The fender pan is removed and a local welding shop is filling the holes from the previously installed and long sense removed cab. Finally the back tires are off, aired down, and getting ready for paint and new tires. Not sure if I want to go with 23x8.50-12 Carlisle Turf Masters to match the new front tires or 23x8-12 Carlisle All Trails for additional grip. It looks like the Turf Masters are a bit cheaper... :confuse:
#117 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted May 30, 2012 - 04:45 PM
Also in the process of making arrangements to pick up a 41 deck outside KC next week. :thumbs:
#118 KennyP ONLINE
  • 40,238 Thanks
  • 46,811 posts
Posted June 04, 2012 - 06:46 AM
The reason I was asking about the spindle size is that I have a pair of spindles, tires and tie rod from an unknown JD. They are 1" and I'd like to have an axle to go with them. The fender pan looked very similar to this!
#119 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted June 04, 2012 - 10:33 AM
I spent some time on JD Parts and found that the 314 uses 1" spindles and the part cross-ref-ed to late 140, 300, 312, 314, and 316k . The 120/140 share the same size. Do you have any pics? I can compare to the original and replacement spindles from my 120.
#120 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted June 04, 2012 - 08:11 PM
Did a bit more work today including some degreasing and power washing parts to be repainted blitz black. I am seriously considering removing the engine and console so I can paint the frame. Am I going insane? :confuse:
Edited by Trav1s, June 04, 2012 - 09:02 PM.
