* * * * * 1 votes
1971 120
612 replies to this topic
#436 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 15, 2013 - 10:40 AM
Well At least without them balance Gear's you don't have to worry about that engine going KaBoom!
That's true. Of the pre 318 300 series tractors only the 300 and a few early 316's have the balance gears.
  • Trav1s said thank you
#437 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted July 15, 2013 - 12:44 PM
A little tip on installing the fender deck that you may want to try is to remove the rear rims and tires. I know this take a little more time but is so much less easier.  Also  I run two or three layers of painters tape on the pedistal ( console) to help it from getting scatched up. It still helps to have another person help too and make sure that you have the dept control bolt and hydro release bolts turned down as far as they can go. Just my 2 cent that might make the job go a little smoother.
Travis you are doing a great job on this 120.  I have been watching your progress and can not wait to see you get it finished so you will be able to enjoy it.
Mark
  • Trav1s and Navy Chief have said thanks
#438 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted July 16, 2013 - 06:39 PM
The surging problem is resolved.  Changed the filter and it still surged.  Turns out one of the release valves was stuck slightly open.  Messed with it a bit tonight and the problem is gone.  I need to readjust the hydro cam since it now has a slight bit of creep but that is nothing to worry about.  Much relief to know it was something to small.  Time to do the final install on the fender pan and hunt for a temporary seat until the Hapco reproductions are ready.
For reference, I will post a video of the surge problem.
  • Navy Chief said thank you
#439 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted July 16, 2013 - 07:17 PM
Here is what happens when the hydro relief valve sticks open.
th_6D01BF83-5B7D-4641-A0BF-CE8E67AEE9BC-
Another while on blocks:
th_C4873C98-9267-45B1-99F9-C5FFB2968BF2-
Edited by Trav1s, July 16, 2013 - 07:19 PM.
  • twostep said thank you
#440 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted July 16, 2013 - 07:21 PM
A couple vids of it running - just for fun!
th_FBF0CE42-28DA-474F-89D8-9487DE205D3E-
I think the idle is a bit low...
th_2C29FA86-5C97-476A-8DF7-F47AA20368F6-
Edited by Trav1s, July 16, 2013 - 07:25 PM.
  • twostep and TractorGuy1994 have said thanks
#441 TractorGuy1994 OFFLINE
TractorGuy1994
  • 259 Thanks
  • 165 posts
Posted July 17, 2013 - 12:58 AM
Thing runs like a Swiss watch! Great little 120!
#442 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted July 17, 2013 - 07:48 AM
Ran to the local Napa and picked up Duplicolor spray on bed line.  I am going to use it on the foot rests on the fender pan.  I will take some pics as I go.  If time allows I hope to do it tonight.
#443 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted July 19, 2013 - 01:46 PM
Finally got the fender pan done!  By no means perfect but great for a worker.  :smilewink:
Edited by Trav1s, July 19, 2013 - 01:47 PM.
#444 wku88 OFFLINE
wku88
  • 22 Thanks
  • 35 posts
Posted July 19, 2013 - 03:06 PM
Hey, that looks familiar!  :thumbs:
#445 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted July 19, 2013 - 09:43 PM
A few more of today's work.
#446 hdg4400 OFFLINE
hdg4400
  • 284 Thanks
  • 348 posts
Posted July 19, 2013 - 10:12 PM
That 120 looks so fine, that I would be afraid to use it and maybe scratch it. Really Great Job!!!
#447 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted July 19, 2013 - 10:19 PM
Thanks!  Pics hide the many small flaws.  I cannot wait to use it after all of this work.  The new carb and the Pointslayer are the best additions so far.
#448 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted July 20, 2013 - 12:15 AM
That thing is looking SWEET! So what did you do about the hydro?
#449 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted July 20, 2013 - 06:58 AM
Release valve was stuck open and it became unstuck when I messed with it.  All is good now.
#450 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted July 20, 2013 - 01:22 PM
So I realized I forgot to install the carriage bold that is used to adjust tension on the hydro level when I reassembled the pedestal.  I spent 20 minutes trying to get that thing installed without removing the battery mounting tray.  Bolt = 0  Travis = 1
Installed the fender pan bolts and  painted the 317 front bumper and bolts so it is ready for the left side hydraulic lines when I get them installed.  I might install the original 120 piece since it is already painted.  While I was under it on the creeper installing the carriage bolt I greased the steering box and the center pivot that connects the steering box to the drag link.  It steers even easier than before.  Once I add a spinner it will one easy to drive machine. :D
Edited by Trav1s, July 20, 2013 - 01:24 PM.
