* * * * * 1 votes
1971 120
612 replies to this topic
#421 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted July 01, 2013 - 08:52 AM
REV, No BLack under the Springs
Also I like your Black grill but mine had no black on it or under it
  • Trav1s said thank you
#422 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted July 01, 2013 - 11:53 AM
The '68 110 I need to pick up has a green grill and springs.  That has to be a later build thing.
  • Navy Chief said thank you
#423 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted July 11, 2013 - 11:08 AM
The carb is here!!!
#424 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted July 11, 2013 - 11:09 AM
The carb is here!!!  Carter 26 rebuilt and ready to go.
Edited by Trav1s, July 11, 2013 - 11:10 AM.
  • twostep and Navy Chief have said thanks
#425 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted July 12, 2013 - 09:40 AM
We have the problem eliminated!!
th_2C29FA86-5C97-476A-8DF7-F47AA20368F6-
This vid is after getting the timing and carb adjusted.  It smells a bit rich at shutdown but does not backfire or diesel.  I am going to go with it as it for now.
th_FBF0CE42-28DA-474F-89D8-9487DE205D3E-
Edited by Trav1s, July 12, 2013 - 10:05 PM.
#426 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted July 12, 2013 - 02:02 PM
Since it is finally running properly (a bit rich for now) I adjusted the creep out of the hydro.  Definitely reassembled it out of adjustment.  Now I have a noisy rear diff when the hydro is engaged in forward and reverse.  Checked fluid (using Type F) and added 1/2 quart.  Ran it around the yard several times and still get the same behavior.  I hope to change the filter tomorrow and will see if that helps.
th_C4873C98-9267-45B1-99F9-C5FFB2968BF2-
Edited by Trav1s, July 12, 2013 - 09:52 PM.
#427 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted July 12, 2013 - 10:00 PM
The 120 & the 314 next to each other. Fender pan waiting for the seat.
#428 Navy Chief OFFLINE
Navy Chief
  • 158 Thanks
  • 421 posts
Posted July 13, 2013 - 04:51 PM
That fender is tricky to reinstall, it scrapped some paint off my console and scratch it, now I have to fine sand it a little and shoot some paint on it
#429 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted July 14, 2013 - 11:45 AM
Another thought about the 120 - All of those mods that I made to steering (including rebuilding the steering box, adding the thrust bearing to it, new center link, and those cool tie rod ends make it very easy to steer.  I ran it around the yard steering with a light left-hand grip on the steering wheel and it was so easy to control. We don't need not stinkin' power steering.  :smilewink:
Definitely time and money well spent.  :rocker2:
Edited by Trav1s, July 14, 2013 - 11:58 AM.
#430 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted July 14, 2013 - 11:50 AM
A few pics from tonights work for your enjoyment. I will get some more pics tomorrow of the work that is not in these pics.
***NOTE: This is a worker, not a show tractor****
Center link that is getting replaced to the tune of $73...
Upgraded front steering pieces
Steering parts for reference.
Edited by Trav1s, July 14, 2013 - 11:51 AM.
#431 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted July 15, 2013 - 08:42 AM
Grabbed a 1410 filter from Napa and hope to swap it tonight.
#432 TractorGuy1994 OFFLINE
TractorGuy1994
  • 259 Thanks
  • 165 posts
Posted July 15, 2013 - 09:17 AM
Now that is a Sweet little John Deere! Would be proud to own that Tractor! im still wanting to get a 140 H-1,H-3 someday!
#433 Trav1s ONLINE
Trav1s
  • 3,298 Thanks
  • 4,353 posts
Posted July 15, 2013 - 09:59 AM
:thank_you:
I wanted a 140 too but found the 120 and the price was right.  After using the 120 with the k301 and my 314 with the k321 I would pick a k301 any day.  Much smoother and plenty of power for the stuff I do.
Edited by Trav1s, July 15, 2013 - 10:13 AM.
#434 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 15, 2013 - 10:21 AM
:thank_you:
Looking really good. I'll second the caution about installing the fender deck. A second person to help will prevent scratching things up. The motor mounts are often shot on 314's. If that's the case the engine will shake the tin right off the tractor. The idle on a 314 is supposed to be set to 22-2300rpms. I know that sound high but without the balance gears a more normal idle speed results in a lot of vibration.
#435 TractorGuy1994 OFFLINE
TractorGuy1994
  • 259 Thanks
  • 165 posts
Posted July 15, 2013 - 10:31 AM
Well At least without them balance Gear's you don't have to worry about that engine going KaBoom!
Edited by TractorGuy1994, July 15, 2013 - 10:31 AM.
  • JDBrian said thank you
