* * * * * 1 votes
1971 120
612 replies to this topic
#376 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted March 16, 2013 - 05:16 PM
Got those elbows installed but did not get to anything else done.  I wanted to work on it today but ran out of time between a long visit at the church and a long phone call with a friend.  Not sure when I will get to the next step of reassembly.
  • larryd said thank you
#377 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted March 17, 2013 - 04:54 PM
Spent some time one the 120. Finished up the wiring and installed the battery tray. I also installed the gas tank. I used self-adhesive foam used on fiberglass caps between the tank, brackets, and frame.
  • KennyP and twostep have said thanks
#378 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted March 17, 2013 - 04:58 PM
Also installed a pto indicator light in the dash. Also pics of those elbows installed on the lift cylinder lines.
#379 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted March 18, 2013 - 08:27 AM
That's looking real nice! Glad the ells worked for the lines! I have some of that foam tape, got a use for it coming up!
  • Trav1s and larryd have said thanks
#380 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted March 18, 2013 - 08:31 AM
I bought that tape when I installed the tonneau cover on my Ram (traded last May) and never used it.  I think I will install it on some other surfaces on the 120 as I do the final install.
One more thought - I will not crank over since I reinstalled the wiring harness.  I think I have energized the wrong pole of my 2-pole solenoid.  Hope to get to that later this week.
#381 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted March 20, 2013 - 08:56 AM
Last night I found the last two stickers to install on the 120.  They were hidden (or buried) and forgotten on the desk.  I installed the warning sticker on the gas tank so it appears to be complete under the hood.  The final sticker that goes on the fender pan will not get installed until I do some additional sanding and paint work when the weather warms up.  Now to get those repop seats from Hapco in my hands.
#382 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted March 23, 2013 - 04:49 PM
Redid the pto indicator light on the dash with a grommet from napa and the same light from eBay. Looks good to me and is more secure than the first try.  The grommet fit perfect and the light pushed right in place.  Much more secure too.
Edited by Trav1s, March 23, 2013 - 04:59 PM.
  • twostep said thank you
#383 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted March 29, 2013 - 04:07 PM
Messed with the 120 wiring today.  It seems that I am not getting power to the solenoid or the starter.  I will break out the FSM and start tracing wires.
#384 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 31, 2013 - 09:33 AM
Wow your tractor is looking awesome, how did you get the green so shinny, is that clear coat?
I need a new coil wire and battery leads like yours
I also have to repair my hood
Im having trouble finding the 110 dash sticker, they have it on ebay but it looks brown not black and Hapco didn't have the one for the 110
I also need to get that sander you have and wire wheel
I have to get that body filler like you did to fill in some scratches
Also you said you used 300 grit sandpaper?
Edited by Spain, March 31, 2013 - 10:15 AM.
#385 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted March 31, 2013 - 01:01 PM
That is standard Deere paint in a spray can.  I have a pretty steady hand and a good eye that helps me get that finish.
The battery leads are are off the shelf stuff from Napa.
If the decal is not available from Hapcoparts then it is likely available from Deere.
That is a basic grinder with a high-rpm wire wheel added.  I have wiped out one and a half of those on this machine.  :watch_over_fence:
I think it was 320 between coats.  I will have to check.  In my experience it is better to go too fine than too coarse.  Wet sanding with 320/400 yielded the best results between coats.
Send me a message if I can be any additional help.
Edited by Trav1s, March 31, 2013 - 01:01 PM.
  • larryd and Navy Chief have said thanks
#386 Navy Chief OFFLINE
Navy Chief
  • 160 Thanks
  • 422 posts
Posted March 31, 2013 - 01:24 PM
I need to find a NAPA around here, I think Im going to go more indepth now that I saw your machine.
Im not looking forward to pulling that axle apart for the trans mission leak, I hear its  bear
I noticed that you put some strip pad under the gas tank on the dash, mine needs that you can see where it rubber from vibration on the gas tank and dash
Edited by Spain, March 31, 2013 - 01:27 PM.
#387 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted April 06, 2013 - 03:46 PM
Stuck the fender pan on to get I out of the way.  Since this is a worker I might just install it as is and be done with it.  The more I look at it the more the 120/140 style grows on me plus it is a fair amount smaller than the 314.  Really happy with my project.  :smilewink:
Edited by Trav1s, April 06, 2013 - 07:55 PM.
  • twostep and larryd have said thanks
#388 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted April 06, 2013 - 07:54 PM
If you send me your address through a message I can cut a couple of feet for you and drop them in an envelope.
#389 jeeper4life OFFLINE
jeeper4life
  • 54 Thanks
  • 81 posts
Posted April 07, 2013 - 10:49 PM
Nice Tractor!
  • Trav1s said thank you
#390 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted April 08, 2013 - 12:44 PM
Real nice Travis good work
larryd
