* * * * * 1 votes
1971 120
612 replies to this topic
#361 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted January 31, 2013 - 08:57 PM
Gary, you are a crazy man!  The cap and wheel look different than this one.  The cap is 1 7/8" wide and the wheel is 2" wide.  I found them on Hapcoparts and will check with Deere.
http://hapcoparts.co...centercap1.aspx
#362 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted January 31, 2013 - 09:33 PM
they are different i did some checking , lol i should have checked before i ran out to the shop in the freezin cold . just hoping i would be able to help you out .
  • larryd said thank you
#363 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted February 01, 2013 - 04:08 PM
317 hard lines are here.
#364 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted February 09, 2013 - 07:22 PM
I ended up using the 317 hard lines and gently bent them to fit the h3 valve. Currently the deck lift is on one remote, front right is on another and the 3rd one is blocked off until I install the left side. The front remote lines were as close to direct fit as I could have hoped. I also replaced the female fittings on the front. Changed the oil, installed the magnetic oil drain plug from Kirk, put never seize on the steering shaft then completed the steering wheel install, and worked on wiring a bit. A new wiring harness would be a nice addition but is not in the budget now.
Edited by Trav1s, February 09, 2013 - 07:36 PM.
  • KennyP, twostep and larryd have said thanks
#365 KennyP ONLINE
  • 38,310 Thanks
  • 45,901 posts
Posted February 09, 2013 - 07:43 PM
Is there any way to take some of the bend out of the hose in pic 4 & 5?  Will the fitting move any to take some of that out?
  • Trav1s and larryd have said thanks
#366 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted February 09, 2013 - 07:56 PM
I will play around with that during the next round of garage time.  Those are the lines for the deck lift cylinder.
#367 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted February 11, 2013 - 09:37 AM
I am going to see if I can pick up a pair 90 degree elblows at Napa to eliminate the tension.
  • KennyP and larryd have said thanks
#368 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted February 12, 2013 - 08:37 AM
Napa ordered me 2 90-degree fittings to eliminate the tension on the line.  Not sure when they will be here.  There were 93 in the Kentucky warehouse... but none anywhere closer to us. :(
#369 Mitchell Cain OFFLINE
Mitchell Cain
  • Validating
  • 48 Thanks
  • 54 posts
Posted February 13, 2013 - 02:39 PM
Nice 71 120
#370 Mitchell Cain OFFLINE
Mitchell Cain
  • Validating
  • 48 Thanks
  • 54 posts
Posted February 13, 2013 - 05:19 PM
Here is a 1970 120
#371 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted February 13, 2013 - 05:20 PM
Thanks... I think I have gazed upon that one on another site.  Mine has a different vib than that one.  I could see my 314 going a bit more like that with the lug tires. :smilewink:
Edited by Trav1s, February 13, 2013 - 05:21 PM.
  • larryd and clarke212 have said thanks
#372 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted February 21, 2013 - 07:42 PM
Those elbows to reduce the tension on the lines will be here tomorrow.
#373 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted February 27, 2013 - 05:19 PM
I am going to rob the good seat off the recently acquired 314 for the 120 since the original seat looks out of place on a repainted tractor.  When Hapco gets the new cushions done I will repaint the base, install the new cushion, and install it on the 120.  Now to get the wiring harness figured out and reinstalled.  And to get two drive pins in place :wallbanging:
#374 Deere Green OFFLINE
Deere Green
  • 24 Thanks
  • 126 posts
Posted March 12, 2013 - 09:24 AM
you finish this one yet?
#375 Trav1s ONLINE
Trav1s
  • 3,308 Thanks
  • 4,363 posts
Posted March 12, 2013 - 09:31 AM
Still need to sort out the wiring... been avoiding that like the plague.  Plus, the 314 has been a great distraction.  Friday looks to be a nice day and I will hit this hard and hope to have it running.  I also need to install those fittings I ordered from Napa.
