d series PTO
8 replies to this topic
#1 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted August 23, 2011 - 09:46 PM
funny story, so my friend finally got the nerve to take my bolens ht20 for a ride and he loved it but he loves wheelhorse and knows the d series is comparable to the bolens ht, but not as engineered =) and he wanted me to ask what engages the pto on the d series. 180 specifically
#2 caseguy OFFLINE
  • 1,628 Thanks
Posted August 24, 2011 - 07:05 PM
I'm a Wheel Horse nut myself, but unfortunately I don't know much at all about the D series tractors. By responding to this, it'll give it a :bump: and maybe someone will come along who knows.
#3 WH1056 OFFLINE
WH1056
  • 64 Thanks
  • 59 posts
Posted August 24, 2011 - 07:23 PM
The manual PTO is engaged by a lever on the left side of the hood stand.
An electric PTO would have a toggle switch on the dash - just below the steering column.
  • 14,796 Thanks
  • 15,495 posts
Posted August 24, 2011 - 07:36 PM
Here's a picture of the one I had, You can see the PTO lever on the side of the dash. This is a 1973 Automatic 18.
#5 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted August 24, 2011 - 09:59 PM
thx for the info, but also i meant does it have pulleys going from the stub on the flywheel turning belts that go to the PTO? if so how many belts?
#6 Texas Deere and Horse OFFLINE
  • 14,796 Thanks
  • 15,495 posts
Posted August 24, 2011 - 10:16 PM
j, On the front of the engine is the clutch, below the engine,you will have a PTO shaft that runs to the back of the tractor for the rear PTO. The clutch has 2 pulleys, different Dia. for different pto speeds, on it and you can also, with the use of the mule drive, power any mid mount (mower deck)or front mount (snow blower) equipment. Just remove the grill to access the clutch.
#7 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted August 25, 2011 - 10:30 PM
so mower decks and snowblowers are belt or shaft driven?
#8 caseguy OFFLINE
  • 1,628 Thanks
Posted August 26, 2011 - 06:44 PM
Belt driven.
#9 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted August 26, 2011 - 09:15 PM
ok. so reallt the only shaft driven impliments are on the rear, so 3 point mowers tillers ect.
