Jd 112h
This topic has been archived. This means that you cannot reply to this topic.
1 reply to this topic
#1 maddhorse OFFLINE
maddhorse
  • 52 Thanks
  • 85 posts
Posted August 22, 2011 - 04:59 AM
This the add found in Sanford, ME.
This is a john deere round fender 112H with a 48" mower deck and snowblower. Tescumseh 10HP original engine. The tractor runs and moves but needs some tinkering.This is an original tractor that hasnt been messed with. The hydraulic lift is mounted but needs to be filled up and needs a belt installed. The engine needs a new throttle cable and choke cable. The tractor just needs to be gone through and gone over before you work it. The mower deck is in good shape with no visiable problems and the snowblower needs to be gone over before using it. 112.jpg
I want it bad but have to fix chimney and put oil in the tank, So it will not happen for me.
#2 Trav1s ONLINE
Trav1s
  • 3,185 Thanks
  • 4,293 posts
Posted September 02, 2011 - 06:29 PM
If the foot boards bolt on it is a 1966 - the first year of the 112. They command big bucks if you find them. 1967 models have welded on foot boards and were much more common. I cannot tell which it is from the pic.
