Left handed lock washers
18 replies to this topic
#1 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted August 19, 2011 - 10:32 PM
Once upon a time I was buying a new left handed 1 1/4 nut for a bush hog and decided I should buy a new lock washer as well . A local experienced ( I think ) hardware gave me a blank stare like you dont see often. My question is - to be properly left handed and not a rebent POS it would have to be heat treated and probably assigned a part number . Can anybody give me such an example ? olcowhand probably can or others - anybody ? This website has people with better guesses than most peoples' facts . Late night dislodgement from brain !!
#2 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 20, 2011 - 06:43 AM
You know, I've never had the need to buy a LH lock washer, so this is a good question! Any time I've worked on a LH threaded part, I just re-used the OE washer.
#3 mjodrey OFFLINE
Posted August 20, 2011 - 06:45 AM
I'm not sure I have seen actual left hand lock washers,although they must make them.
It would be very easy though,to re-make a right hand one into a left hand one.All you would have to do is put them in a vise,and give them a slight twist the other way,with no heating required.If done properly,they would not be just a re-bent POS.
#4 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted August 20, 2011 - 06:57 AM
And my wife used to think my curiosity was weird. She is slowly coming around after 25 years. :bigrofl:
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 20, 2011 - 07:12 AM
I have never thought of that as an issue at all! All the left handed stuff I have encountered at work is usually pipe fittings that don't use lock washers. Maynard has the solution for that dilemma. Now if I can only remember that!!
#6 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 20, 2011 - 07:14 AM
I know some lock washers are so hardened, that if you tried twisting them, they would snap in-two. Cheap lower grade ones would twist without any problem.
#7 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 20, 2011 - 07:21 AM
I have a bunch of 1/2 inch ones. I'll have to see if they can be converted. Probably grade 5.
#8 mjodrey OFFLINE
Posted August 20, 2011 - 07:37 AM
You'd only have to twist them just a fraction in the opposite direction,I think they'd be alright.
#9 coop OFFLINE
coop
  • 24 Thanks
  • 103 posts
Posted August 20, 2011 - 09:50 AM
The cut in the washer is usually at an angle / to dig into nut and metal you are fastening, by reversing the washer you wold lose the locking part and as you tightened the nut you would actually cut into the nut. You need to find some "star" type washers.
#10 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted August 20, 2011 - 10:49 AM
Coop, you beat me to it. As I read the post I was picturing a lock washer and had the same thought.
#11 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted August 20, 2011 - 12:11 PM
After I had posted , the thought that a google could be done came later. Oh well , the fun was worth it. Sparky
#12 J1morris OFFLINE
J1morris
  • 1 Thanks
  • 9 posts
Posted August 20, 2011 - 12:39 PM
Left Handed Lock Washers are avaiable in most all sizes from avaiation hardware sources. You will pay the aviation premium but they are high quality Hope this helps.
  • Sparky said thank you
#13 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted August 20, 2011 - 04:38 PM
I assume J1 comes from Piper J1 . You certainly don't need your prop to fall off . I have hand prop - ed cherokees and didn't think to remember about this. Thanks J1. Sparky
#14 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted August 20, 2011 - 09:35 PM
Ok - now for the weird part . My daughter is studying to be an aircraft A + P mechanic , her husband is a Navy diesel mechanic . Maybe I should have asked them , but I got a good answer HERE . HEE HEE HEE. Sparky
#15 KennyP OFFLINE
  • 40,899 Thanks
  • 47,099 posts
Posted August 21, 2011 - 06:19 AM
Glad you found an answer, Sparky. Now I know where to find good left-handed hardware.
