Chopping Silage... COMPLETED!
34 replies to this topic
#1 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted August 17, 2011 - 10:26 AM
Been chopping the last 2 days on silage corn, then switched today to alfalfa/orchard grass/johnson grass. Well, it's still too damp, but in the process of trying, we had a close call. Dad plugged the chopper, then went to back up while clearing the pickup head. He backed too far & jackknifed the wagon hitch to the chopper & pulled out the hitch plate on the chopper. The dump wagon took off through a fence & coasted to a stop on the middle of a ridge. Had it turned either way, it would have went down steep hills, & most likely been destroyed. This wagon costs going on 20 grand new & is only -5yrs old!
Luck was on our side today. Dad's judgement is not as sharp as it once was, but then we all make mistakes at any age. I know I do! We're switching back to corn silage after lunch & letting the hay dry down more. May not chop it until Friday.
Edited by olcowhand, August 26, 2011 - 02:57 PM.
#2 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted August 17, 2011 - 10:34 AM
I am glad to hear luck was on your side. 20K, wow, that is one expensive wagon.
#3 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted August 17, 2011 - 10:48 AM
Wow Dan that was a close one.
Hope your Luck improves.
#4 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted August 17, 2011 - 11:29 AM
Proud it all worked out.
#5 mjodrey OFFLINE
Posted August 17, 2011 - 11:38 AM
:ditto:
#6 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,591 posts
Posted August 17, 2011 - 11:48 AM
Sometimes lady luck is on our side.Its when she's not that things can get quite costly.Glad she was on your side this time.Larry
#7 MH81 OFFLINE
Posted August 17, 2011 - 04:39 PM
Glad it all worked out, neither Dad nor the wagon were damaged.
#8 KennyP ONLINE
  • 40,177 Thanks
  • 46,786 posts
Posted August 17, 2011 - 05:01 PM
Good to hear no more than a hitch and pride were damaged. Hope the hay dries for you.
#9 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted August 17, 2011 - 05:19 PM
IF no more problems, we MIGHT get this pit finished by Friday.
#10 KennyP ONLINE
  • 40,177 Thanks
  • 46,786 posts
Posted August 17, 2011 - 05:39 PM
That pit looks good nearly full. I happy you had to resources to get it in shape, and I'm not talking money. That is probably one little item off the list of things needing help around there. Something always needs attention on a farm.
#11 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted August 17, 2011 - 05:45 PM
We've only chopped for about 16hrs total, but when we're chopping....we're chopping! Hoping to chop the haylage to go on top of what's there, then cap off with more corn silage. There's an auction Saturday we'd like to go to, so we're shooting to finish Friday if at all possible. Then we like the other large pit, which is still 1/3 full.
#12 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted August 18, 2011 - 07:10 AM
Is that gravel on top of the chopped up corn? how do you pick the gravel out?
#13 Cvans ONLINE
  • 7,101 Thanks
  • 6,299 posts
Posted August 18, 2011 - 07:17 AM
Do I detect another tractor purchase Daniel?:yelclap:
#14 KennyP ONLINE
  • 40,177 Thanks
  • 46,786 posts
Posted August 18, 2011 - 07:20 AM
Looked like rain was coming your way this morning. Hope not, would like to hear you got it all chopped up.
#15 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted August 18, 2011 - 08:08 AM
No, that's the silage itself. What you are likely seeing is the bits of chopped stalk. In the pic from above, the front of the pic is the gravel drive, but what's behind the beginning block is all silage.
