* * * * - 1 votes
Long live the 2 wheelers
371 replies to this topic
#346 Flat32 OFFLINE
Flat32
  • 11 Thanks
  • 6 posts
Posted September 12, 2016 - 06:35 PM
http://youtu.be/sgDI1q5420k
Trying a video link.
  • Gtractor and Tbrooks have said thanks
#347 DougT ONLINE
DougT
    Dog Approved
  • 7,076 Thanks
  • 5,061 posts
Posted September 12, 2016 - 08:07 PM
The flywheel fan and tin work that is missing is listed on ebay now.
#348 Flat32 OFFLINE
Flat32
  • 11 Thanks
  • 6 posts
Posted September 13, 2016 - 03:10 AM
Thanks for the info.  I have the tin parts and fan although the cylinder cover tin is so flimsy I'm going to reproduce it in thicker material.  No original carb, using an old Briggs updraft.  What I don't have is the dog nut for the engine hand crank. Seems like the dog nut originally fastened to the flywheel with three 1/4 inch screws.
The wheel hubs on mine are apparently not original.  They are 5 by 4.5 bolt pattern and I stuck a couple old car wheels on them having nothing else at hand.
#349 DougT ONLINE
DougT
    Dog Approved
  • 7,076 Thanks
  • 5,061 posts
Posted September 13, 2016 - 10:42 AM
He does have an original carb listed here.  http://www.ebay.com/...EYAAOSwvzRX0IIv
I didn't see the crank piece though. The Standard wheels mount straight to the axle. They don't use bolt on hubs.
  • Flat32 said thank you
#350 Alc ONLINE
  • 7,125 Thanks
  • 7,530 posts
Posted September 14, 2016 - 02:52 PM
I picked up my grandfathers Standard Walsh Here's some pictures while it was still on the trailer We are on vacation this week so maybe I can get a better idea on what I'm going to need to make it run again over the weekend Looks like the exhaust is missing I did spray some PBlastet on the plug looks like it's been in there for a long timeimage.jpeg
  • earthgrinder, DougT, Gtractor and 2 others have said thanks
#351 DougT ONLINE
DougT
    Dog Approved
  • 7,076 Thanks
  • 5,061 posts
Posted September 14, 2016 - 04:20 PM
That little cast elbow thing was all it ever had for exhaust. There was a top on the battery box originally. Doesn't look like it would take much to get it going. I think pulling the oil pump, cleaning it out, and making sure it works first would be a good idea though.
  • Gtractor said thank you
#352 earthgrinder ONLINE
earthgrinder
  • 1,128 Thanks
  • 499 posts
Posted September 14, 2016 - 05:10 PM
I picked up my grandfathers Standard Walsh Here's some pictures while it was still on the trailer We are on vacation this week so maybe I can get a better idea on what I'm going to need to make it run again over the weekend Looks like the exhaust is missing I did spray some PBlastet on the plug looks like it's been in there for a long timeattachicon.gifimage.jpeg
Are you bringing it to jacktown in October?
#353 DougT ONLINE
DougT
    Dog Approved
  • 7,076 Thanks
  • 5,061 posts
Posted September 14, 2016 - 05:46 PM
Al, what year is that tractor? The serial will tell us.
#354 Alc ONLINE
  • 7,125 Thanks
  • 7,530 posts
Posted September 14, 2016 - 06:17 PM
Charlie I promised my cousin I would take it to Jacktown next month even if I don't get it running Doug where's the serial # located ? Also did the exhaust elbow clamp on the little short pipe sticking out ?
#355 DougT ONLINE
DougT
    Dog Approved
  • 7,076 Thanks
  • 5,061 posts
Posted September 14, 2016 - 07:07 PM
The tag should be on the gas tank bracket facing the handles. If the tag is missing, the number should be stamped in the front around the fill plug. The exhaust casting that mounts to the cylinder is all they ever had originally. From what I can see you're not missing anything there.
#356 Flat32 OFFLINE
Flat32
  • 11 Thanks
  • 6 posts
Posted September 18, 2016 - 01:05 PM
Located a crank dog for my Standard T.  Passed on the ebay Zenith original carb since the Briggs carb works fine needing only a throttle control hookup,  My ST is a 1938 model w/o governor which may not matter, but this tractor will have to earn it's garage space by being useful.  Have ordered a Brush Grubber and plan to make a snowplow attachment bracket that can also take the Grubber on a stick.  Contemplating some sort of towed grader for gravel driveway work.  14 acre property is on a hill with about 10 acres rented for farming leaving a sizable "playground" needing maintenance.
I'm very anxious to get the individual wheel brakes cleaned up and working to see how effective they really are.  I ran it a very short time steering with the handles only and the amount of muscle it took leaves me wondering if the differential is working correctly.
No plan to do any tilling, cultivating or mowing with it since those jobs are covered by other equipment.
#357 karel OFFLINE
karel
  • 2,225 Thanks
  • 1,443 posts
Posted November 14, 2016 - 11:43 PM
  • Alc, Lauber1 and Clifford Bridgford have said thanks
#358 jimmy G ONLINE
jimmy G
  • 1,267 Thanks
  • 805 posts
Posted November 15, 2016 - 01:02 AM
That is one cool butt buggy! Folding seat, brake's, dump box? tell me that's not a 14 doing 1/4 cord Pull's lol
#359 Alc ONLINE
  • 7,125 Thanks
  • 7,530 posts
Posted November 15, 2016 - 06:19 AM
Simplicity model 300
Karl is that cart factory for your tractor ? Where's the pivot point , at the tractor or cart ?
#360 karel OFFLINE
karel
  • 2,225 Thanks
  • 1,443 posts
Posted November 15, 2016 - 06:38 AM
It is a stock simplicity dumping sulky cart. the pivot point is at the tractor hitch.wich isn't much.
