Which belt groove ?
8 replies to this topic
#1 williamc120 OFFLINE
williamc120
  • 3 posts
Posted August 15, 2011 - 06:25 PM
I have a C-120 8 speed Wheel Horse with a 42" rear discharge mower deck on it. I just recently installed the deck and am unsure about which belt groove I should use. (Double sheave out of motor, inside or outside). I know there are some experts on here that can answer this.
Thanks in advance.
#2 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted August 15, 2011 - 07:06 PM
How does the belt tension to kick in the mower? My three C-120 auto's, and my GT14 all HAD to go in the outside one, as it WAS the PTO engagement pulley with a clutch facing on it..
#3 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted August 15, 2011 - 10:08 PM
The manual for my D160 says inner groove, the outer is for the Rear PTO on mine. I do have to adjust the Tachamatic adjuster almost all the way out to get good tension on the deck drive pully.
#4 WH1056 OFFLINE
WH1056
  • 64 Thanks
  • 59 posts
Posted August 20, 2011 - 05:12 PM
This should help:
#5 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted August 20, 2011 - 06:41 PM
Wow how my memory has failed me. I forgot how the pto clutch had 2 grooves. After seeing the parts diagram, then it came back to me. In my weak defense, it has been many years since owing my last Wheel Horse.
#6 MikesRJ OFFLINE
MikesRJ
    One of the 1st 500!
  • 71 Thanks
  • 118 posts
Posted August 21, 2011 - 06:04 AM
Inner groove is correct as ColdOne suggested.
#7 williamc120 OFFLINE
williamc120
  • 3 posts
Posted August 21, 2011 - 06:50 AM
Thanks for the info.
#8 williamc120 OFFLINE
williamc120
  • 3 posts
Posted August 21, 2011 - 06:51 AM
Many thanks for the diagram, this is very helpful.
#9 mjodrey OFFLINE
Posted August 21, 2011 - 07:25 AM
williamc120,welcome to the forum,glad to have you with us.
