I built a driveway sealer spray system
19 replies to this topic
#1 joshtiffany OFFLINE
joshtiffany
  • 3 Thanks
  • 23 posts
Posted August 15, 2011 - 09:49 AM
I built a driveway sealer spray system from parts sourced at Tractor Supply and Craigs list.
It utilizes a 220 gal tank and a trash pump, wand and pressure valve. It cost around $500 but saved me over $1500, as I have a 600' driveway and am really persnickety about the driveway.
If anyone would like a picture or has any questions, let me know. I am new to the group, so not sure how to post picture at this time.
JT
  • WNYTractorTinkerer and Sawdust have said thanks
#2 olcowhand ONLINE
  • 38,806 Thanks
  • 30,702 posts
Posted August 15, 2011 - 10:50 AM
Sounds interesting, but sadly, my drive is gravel & will likely stay that way forever. No time to look up the pic uploading instructs, but maybe someone will guide you. Gotta run.
#3 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted August 17, 2011 - 06:31 AM
JT
Would love to see pictures, even if my drive is gravel as well.
Easiest way to add a pic is to either click edit post on your original, or any of the reply buttons here. Then click "Go Advanced". You will have a few more buttons above the text box. One of them is a paperclip, that's your attachment manager. Once that's open, there is an Add Image button. Then Select Files. This last click opens up a standard windows screen to navigate around in your computer and find the files.
Once you upload, you can either click Insert Inline or Done. INS Inline will put them wherever you left your cursor in the text box, Done will put them at the end of the post in a separate box. Either way is right, just what you prefer.
If you want to play, there is a members test area on the forum page 3/4 way down or a little more. Those posts delete after a period of time.
Good luck, & ask questions.
Edited by MH81, August 17, 2011 - 06:44 AM.
#4 KennyP ONLINE
  • 35,089 Thanks
  • 44,105 posts
Posted August 17, 2011 - 06:37 AM
Did you hit post reply too quick there?
#5 joshtiffany OFFLINE
joshtiffany
  • 3 Thanks
  • 23 posts
Posted August 18, 2011 - 05:53 AM
#6 joshtiffany OFFLINE
joshtiffany
  • 3 Thanks
  • 23 posts
Done...Thanks Kenny
#7 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted August 18, 2011 - 06:30 AM
Yes I did LOL.
Wanted to go back & check the labeling of the buttons and hit post instead of cancel.
Edited it, but thought I'd get it in before anyone noticed it.
Oh well, you're too fast Kenny. :D
#8 MH81 OFFLINE
  • 29,957 Thanks
  • 29,757 posts
Posted August 18, 2011 - 06:33 AM
[ATTACH=CONFIG]19266[/ATTACH]
Is that your unit, or one you patterned it from? Looks very capable. Thanks for the pic.
#9 olcowhand ONLINE
  • 38,806 Thanks
  • 30,702 posts
Posted August 18, 2011 - 03:59 PM
By the looks of that pic, it's a rep photo. Looks like you regulate the pressure with the return hose valve.
#10 joshtiffany OFFLINE
joshtiffany
  • 3 Thanks
  • 23 posts
Posted August 19, 2011 - 08:41 AM
I will post some additional close ups on the unit. The pressure is regulated by the return flow valve and the ball valve on the wand. The only item I could not get at TS was the asphalt nozzles, which I purchased online.
  • Sawdust said thank you
#11 JDBrian OFFLINE
  • 9,599 Thanks
Posted August 19, 2011 - 10:02 AM
Nice build. You could probably use that to spray any thick coating.
#12 olcowhand ONLINE
  • 38,806 Thanks
  • 30,702 posts
Posted August 19, 2011 - 10:47 AM
With the right nozzle, and not too thick for the pump, yes, it should spray most anything.
#13 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted August 19, 2011 - 10:50 PM
Well that sounds like something that I tried to build several years ago to spray Mole-lasses on sorry hay was trying to fit it on tractor when hay unrolled it would spray. Never got it right
#14 daddy2kids OFFLINE
daddy2kids
  • 2 posts
Posted January 30, 2017 - 12:28 AM
Hello everyone.
I need a driveway sealer. I used one before but it wasn't reliable.
I want one that is durable and will last a long time.
The one I used cracked after a few months. :(
It must have been a cheap knockoff. :(
Thanks.
#15 Cat385B ONLINE
    HAZMAT CAT
  • 13,145 Thanks
  • 9,624 posts
Posted January 30, 2017 - 07:34 AM
Hello everyone.
Sealer for driveway cracks
Thanks.
As far as spammers go.
That was well written.
Thank you.
Please wait quietly while DougT makes up your consolation prize.
  • DougT and KennyP have said thanks
