Delco Generator bearing grease
2 replies to this topic
#1 handdsaw OFFLINE
handdsaw
  • 5 posts
Posted August 14, 2011 - 09:18 PM
Anybody have any thoughts on what grease is recommended for the ball bearings in a Delco generator?
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted August 16, 2011 - 11:34 PM
We always used chassis grease in D/R starter/generators bearings. ......Just be sure not to put too much in, and the bearing must have a seal or shield on the side that goes toward the armature.
#3 handdsaw OFFLINE
handdsaw
  • 5 posts
Posted August 17, 2011 - 08:48 AM
Thanks for the heads-up. I thouht about just doing that, but then thought maybe it wouldn't hold up is why the wanted a heavier grease. I have found that most bearing application require a non-EP grease that is lithium based. I have a can of Valvoline wheel bearing grease for Fords, think I'll just use that.
