2 more TUBEFRAMES!!! G14......oh and a....RARE G11 !!!!!!!!!!!!!!!
27 replies to this topic
#16 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted August 14, 2011 - 06:59 PM
Sorry about the Broken axle :(
I had that happen to my 850.
Its not a very common thing to have happen but I remember Bruce saying that the part was the weak spot in the transmission.
#17 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted August 15, 2011 - 03:44 AM
no problem, i have extra trans, my question though...will a high low trans from a 1050 fit in????
#18 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted August 15, 2011 - 05:24 AM
My only concern would be the driveshaft. Since the G11 has that belt tensioning system for a clutch, it may be a different length....
I'd probably wait until you find a 3 speed to keep it more original.
#19 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted August 15, 2011 - 09:59 AM
I have a 3 speed out of a G10 but shipping may be costly.
#20 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted August 15, 2011 - 03:29 PM
what about the 1963 800 trans?
#21 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted August 15, 2011 - 08:01 PM
That would work....
#22 bhts OFFLINE
bhts
    Bob's Lawn and Garden LLC
  • 1493 Thanks
  • 2181 posts
Posted August 15, 2011 - 09:59 PM
Nice looking tractors Brad,Sorry to hear about the axle but hope you get it going soon.
#23 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted August 16, 2011 - 04:18 PM
GOOD NEWS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I got the G11 Running, Mowing, and now DRIVING!!!!! I ended up putting a 6 speed from a 1050 in it. Took some time( about 2 hrs ) to swap in the 6 speed with the diff lock but that was because I never did a tubeframe trans swap before and I ran into a couple little mishapps but its all up and driving now.
Brian, as far as the driveshaft length not knowing if it would be long enough....it in fact was. All I had to do was swap the little adapter that allows the driveshaft and trans to interlock. The G11 originally had a keyed shaft where as the 1050 had a spline shaft. Just unbolted 2 out of the 4 bolts ( 1/2" nut and allen screw ) and swapped the adapter and that was it. Other than that it was a direct bolt in.
I will take a vid sometime soon for ya's till then Thanks for all the comments and have a good one.....Brad
#24 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted August 16, 2011 - 08:25 PM
Glad to hear you got it running and driving! :dancingbanana:
Good to know the drive shafts are the same length. I never really measured the 2 before so I wasn't sure if they were different sizes or not.
#25 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted August 16, 2011 - 11:27 PM
So, Brad, you now have a 12-speed tractor if you incorporate a shifter for the hi/lo range on the trans ?
#26 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted August 17, 2011 - 03:35 AM
Yeah I suppose I do. It moves along really good now and I left the trans in low range. I used the original Trans top cover so there is no lever for the high low unless I reach underneath. If I have the high range on the pulleys and put the trans in high, wouldnt I go really fast????
#27 Bruce Dorsi ONLINE
Bruce Dorsi
  • 5122 Thanks
  • 2911 posts
Posted August 17, 2011 - 08:33 AM
Sounds like that could be fun! ......You could drive it to Dover this weekend. :bounce:
#28 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted August 17, 2011 - 04:38 PM
I heard it could rain possibly....I need to find a cab for it that has a windshield wiper then im all set
