Ford LGT 165 PTO Question
4 replies to this topic
#1 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted August 13, 2011 - 06:01 AM
I have noticed that, with the mover drive belt removed, the front (electric) PTO clutch spins freely when the engine is running, regardless if the PTO switch is on or off. Is this normal?
I would think that the PTO switch is what engages/disengages the clutch, and in the off position, the clutch would only rotate when the engine is running.
In my case, the PTO clutch continues to spin when the engine is turned off (like it is free wheeling) and eventually stops.
Any suggestions or thoughts?
GEL
#2 KennyP ONLINE
  • 38,385 Thanks
  • 45,933 posts
Posted August 13, 2011 - 06:06 AM
Without a belt on them, they will freewheel. Bearings may be getting a bit loose, but most likely spinning because of the centrifugal forces.
  • MH81 and nycub122 have said thanks
#3 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted August 13, 2011 - 06:13 AM
KennyP:
Do you mean the bearings in the PTO clutch?
If the bearings were tight, would the clutch still freewheel?
You have been quite a help, and I thank you
GEL
#4 KennyP ONLINE
  • 38,385 Thanks
  • 45,933 posts
Posted August 13, 2011 - 06:21 AM
If they are getting loose, bearings will turn easier. Spin it by hand and listen for anything that sounds like it may be worn. Check for wobble. I'm not saying they are bad, just getting a bit loose, which lets it keep spinning longer after you shut the engine off. If no wobble, no loud bearing noise, should be fine.
  • nycub122 said thank you
#5 poncho62 ONLINE
poncho62
  • 1,756 Thanks
  • 1,666 posts
Posted August 13, 2011 - 06:28 AM
All 3 of mine spin when shut off with no belt.....I am sure your PTO clutch is engaging when you hit the switch, with the belt off its hard to see it.....Check it with the engine off, just turn the key to on and hit the PTO switch.....you shouldnt be able to move the clutch.
