Found Old 112 round fender
15 replies to this topic
#1 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 12, 2011 - 11:10 PM
I found an old 112 round fender with mower deck snow plow and tiller for $550. Tractor runs but everything pretty ruff shape except mower deck. I still think it is good deal but low on funds from fixing up the last one I bought. I was just wondering if this is a good deal never look at 1 this old.
#2 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted August 12, 2011 - 11:29 PM
It is a great deal. Considering what a tiller would bring alone, plus the blade and mower deck, you are basically getting the tractor for free.
#3 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 12, 2011 - 11:35 PM
That's what I thought it is just getting my wife to see it that way. If was not for my 312 costing me so much for motor mounts. Do you know anyone that would want the tiller & what one is worth? It's all there and everything moves just rusty.
#4 Trav1s ONLINE
Trav1s
  • 3,189 Thanks
  • 4,294 posts
Posted August 13, 2011 - 07:48 AM
What year is it? A '66 112 is a rare beast. That could change everything.
What's it worth?
Blade in good shape is worth $150+, a solid mower deck is worth $150 in my book. After a fair amount of reading I am not a fan of the hh100 but would not turn a 112 way if the price was right.
#5 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted August 13, 2011 - 08:37 AM
fishman, if the foot treads are welded to the side of the main frame, it's a 1967. If the foot treads are bolted to the main frame, it's a 1966. As for the purchase price, you did fairly well. As Trav1s stated, a good blade right now can go as high as $150. I saw original 46 decks go for as high as $200 already. As for the tiller, if it's a 30 tiller, and due to the rust, you should be able to sell it for anywhere between $75-$125. This asking price would also depend on the condition of the tines. If it's a 31 tiller, maybe start off asking between $125-$150. Also, to help convince your wife you made a good deal, if the tractor is determined to be a '66 112, the price you paid is well worth that for the tractor alone, for Deere only made 1000 112's in 1966. 1967 112's adverage between $350-$500, again depending on condition. I think you did great, and let me be the first to welcome you to the art of collecting!
I have five round fendered 112's and never had a problem with the tecumseh engines. Carb's can be a pain sometimes, but other than that, I'd almost rather work on the tecumseh motors more than the kohler's. Have fun and enjoy! If you have anymore questions, just ask away, and we'll be more than willing to help out as much as possible.
#6 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 13, 2011 - 09:40 AM
Thanks for all the info. I think the foot treads are bolted on. Back tire are dry cracked but the front are starting to split.
#7 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 13, 2011 - 09:58 AM
Jd 112 HH100 115034A. 6270. 12082. Motor T-2314. 007836m these are the numbers on it.
#8 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted August 13, 2011 - 10:41 AM
Congratulations on the 112. It sounds like a nice setup with all the attachments. If you get a chance post some pictures.
#9 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted August 13, 2011 - 12:18 PM
Should be a 1967
1966 112 serial numbers 2551-3550
1967 112 serial numbers 3551-100,000
  • Trav1s said thank you
#10 reece110 OFFLINE
reece110
  • 20 posts
Posted August 13, 2011 - 02:30 PM
you could turn around and sell everything seperate for a profit!
#11 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 15, 2011 - 08:35 PM
Some pictures of the tractor
#12 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted August 16, 2011 - 06:05 AM
The tractor's id is T2314, which is the type code, and the serial number is 007836, the "M" on the end of that number indicates place of manufacture, which "M" meaning Horicon, Wisconsin. The HH100 numbers is the engine model number and serial number. Using WFM's registry, the T2314007836M gives this info:
Here is the information about the Tractor T2314007836m Model:112 Typecode:T2314 Serial Number:7836 Model Year:1967 Engine Model and Size:HH100 Tecumseh 10HP Lift Type:Manual Paint:Green Manufactured Location:Horicon, WI
Meaning it's a 1967 112.
#13 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 16, 2011 - 07:19 AM
Thanks for the information. If I do buy this tractor I'll post more pictures. I wish when I was there I would have took more the tiller & plowed looked right but the mower deck idk it was oval wheels & really good shape.
#14 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 17, 2011 - 05:45 PM
I just Another found a 66 Jd 110 trying to work out deal all the use it for is plowing. What motor should be in it. Cause it had a kholer. Said drive belt is slipping alot but otherwise runs good.
Edited by fishman, August 18, 2011 - 06:44 AM.
#15 Tmo OFFLINE
Tmo
  • 360 Thanks
  • 486 posts
Posted August 18, 2011 - 06:11 AM
I just found a 66 Jd 110 trying to work out deal all the use it for is plowing. What motor should be in it. Cause it had a kholer. Said drive belt is slipping alot but otherwise runs good.
Original engine is a K181 Kohler 8 hp. There are two drive belts, a primary and a secondary. Both probably need replacing. Be sure you used JD belts - aftermarket belts aren't too JD's specifications and will not perform well nor last as long.
