Briggs Booster Fan Needed.... Anyone Have Spare?
9 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 11, 2011 - 08:46 PM
I decided to but the Caterpillar (88 Craftsman GT18) back together today. I went to put the booster fan Austin sent me on and "bang" it hit the shroud... so I thought hmmm... So I went and got the old one out of the junk pile and found the issue.... the back part isn't as long as the original so it doesn't even reach the flywheel.... ugh... So now I need another one... Briggs Opposed Twin is good engine, just wish I could put it back together!!
#2 johnboggs21 OFFLINE
johnboggs21
  • 18 Thanks
  • 184 posts
Posted August 11, 2011 - 08:57 PM
Got a picture of one? Ive got lots of briggs parts kicking around. Any way you could shim it up and make it work?
#3 MH81 OFFLINE
Posted August 12, 2011 - 04:04 AM
Yeah Casey, bust out that camera!
Just kidding, sorry to hear of your assembly woes.
#4 KennyP ONLINE
  • 40,056 Thanks
  • 46,736 posts
Posted August 12, 2011 - 04:41 AM
:wewantpics::wewantvideo::wewantpics::wewantvideo:
#5 mjodrey OFFLINE
Posted August 12, 2011 - 04:54 AM
:ditto::ditto::ditto::D:D:D:D
#6 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted August 12, 2011 - 11:33 PM
washers
#7 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted August 12, 2011 - 11:43 PM
washers
It's beyond washers... it's a good 3/4 to an inch too wrong...
#8 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted August 12, 2011 - 11:49 PM
then your missen somethin cause thats all thaat was on my gt18
#9 EricFromPa ONLINE
EricFromPa
  • 3,966 Thanks
  • 3,244 posts
Posted August 13, 2011 - 01:54 AM
If you are using a newer Plastic Vayne flywheel you need something like this.
BRIGGS & STRATTON FAN BOOSTER # 213460 OEM PART! IJE3 | eBay
The coupler is 2 inches long.
Here is one off of a slightly older 18hp twin.Should work on yours.
Briggs & Stratton Opp Twin FAN BOOSTER Grasshopper | eBay
And here is the Old points engine Briggs 16 single and 16 twin booster.It has a pulley for Starter genny for the Singles.These are slightly smaller around than the ones up top.
Simplicity 2012-H Briggs Stratton Engine Booster Fan | eBay
Here is one of the narrow booster fans.I'm guessing this one is like the one you have.
Briggs & Stratton 18HP 2Cyl Side Shaft Eng Flywheel Fan | eBay
#10 johnboggs21 OFFLINE
johnboggs21
  • 18 Thanks
  • 184 posts
Posted August 13, 2011 - 01:28 PM
cut a peice of pipe the right size.
