Ignition coil
6 replies to this topic
#1 maddhorse OFFLINE
maddhorse
  • 52 Thanks
  • 85 posts
Posted August 11, 2011 - 06:37 PM
tractor just stopped running went through and found my coil had died tested it and no good. I bought a MSD Blaster. Did I go to far? Tractor now runs at low idle but high she dies out. I plan on checking to ensure fuel is getting to carb tommorw but I cant help but think I may have made a mistake and put to much into the ignition system. Any comments advice?
#2 Billygoat OFFLINE
Billygoat
  • 76 Thanks
  • 206 posts
Posted August 11, 2011 - 07:25 PM
What tractor/engine do you have? If it's a Kohler, good chance it should have an internal resistor in the coil.
#3 maddhorse OFFLINE
maddhorse
  • 52 Thanks
  • 85 posts
Posted August 12, 2011 - 04:15 AM
K301 - Kohler 12horse It has external resistor I replaced at the same time as coil. I changed the points to just to be sure. I think I have to much output to the points and resistore. I will tinker later today.
#4 MH81 OFFLINE
Posted August 12, 2011 - 04:47 AM
You may want to change your condenser too.
Good luck and let us know what you find. Ignition problems can be like trying to pick up smoke sometimes.
#5 maddhorse OFFLINE
maddhorse
  • 52 Thanks
  • 85 posts
Posted August 12, 2011 - 06:38 AM
I messed up between resistor and condensor. I replaced condensor and I have no resistor internal or otherwise. Hmmm I think that could be a problem?
#6 MH81 OFFLINE
Posted August 12, 2011 - 07:05 AM
Without the resistor, you can have a lot of current flow. It may not be gapped enough to break connection at higher RPMs, this will chew up your points quick. I'd put a resistor in there regardless of what else you find.
#7 maddhorse OFFLINE
maddhorse
  • 52 Thanks
  • 85 posts
Posted August 12, 2011 - 09:56 AM
This afternoon I will just go to dealer and get the right coil with internal resistor for her. I am ordering the pointsaver from Kirt engines and then I will use the higher out put coil.
