Tool Shed
38 replies to this topic
#1 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted August 11, 2011 - 05:28 AM
IF everything works out, this weekend I will have a new roof for my work area. I am getting (hopefully) a 12X20 car port for $100. I will have to remove the 8X20 lean-to I have now. But this will give me a lot more room to work on things. It only has 4 posts, I plan to add 2 more at the middle. That will let me put a cross beam to attach the winch to for lifting heavier things. If I get it, I will post some pics of it before I take it apart. I plan to number everything so it will be easier to put back together. The posts that are on it will be moved closer to the ends. Should give more room to put tractors under. Wish me luck!
#2 Bolens 1000 ONLINE
  • 14,890 Thanks
  • 18,097 posts
Posted August 11, 2011 - 05:34 AM
Hope everything goes smoothly for you Kenny.
#3 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted August 11, 2011 - 05:54 AM
Thanks. I should know for sure this evening. If so, I'll take it apart Sat. and haul home. Be next month before I can start to get it in place.
#4 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted August 11, 2011 - 06:59 AM
I drew up a sketch to show what it will look like with the center posts.
Center posts uprights will be 4X4, cross beam will be 4X6. I don't plan to lift much weight from this, maybe front or rear of tractor to work under with supports under tractor. Not going to rely on winch to hold up.
#5 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted August 11, 2011 - 07:13 AM
Looks good Kenny. I wish you luck getting the extra space you want. Can never have enough space, it always fills up :D
#6 MH81 OFFLINE
Posted August 11, 2011 - 08:30 AM
Never have enough roof. Good luck, sounds like a good deal.
#7 JDBrian OFFLINE
  • 9,601 Thanks
Posted August 11, 2011 - 09:46 AM
That's good news Kenny. I was just talking to my wife about adding a section on to the back of the garage. Our 2 car garage has turned into a 3 tractor and piles of stuff garage!! I would consider getting a metal beam for across the centre. This would allow you to use a beam hoist and move it across the span. You can maybe find one used since it is only a 12 foot span.
#8 daytime dave OFFLINE
  • 4,782 Thanks
  • 6,522 posts
Posted August 11, 2011 - 11:01 AM
I hope it works out Kenny. It looks very useful. I like the idea of a center lift as well. Good luck.
#9 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted August 11, 2011 - 11:12 AM
Looks good Kenny. Hopefully everything goes smoothly.
#10 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted August 12, 2011 - 05:33 AM
I already have my 12 volt winch attached to a rolling frame. Just need to attach it to the beam cross ways so it will move from side to side. Thanks for the suggestion.
#11 mjodrey OFFLINE
Posted August 12, 2011 - 06:09 AM
Wish me luck!
Yeah,good luck Kenny.
#12 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted August 12, 2011 - 06:21 PM
I paid for it today, will take it down in the morning if it's not raining. I plan to mark each piece so it will be easier to put back up. And there will be some pics. Stay tuned!
#13 Cvans ONLINE
  • 6,453 Thanks
  • 6,051 posts
Posted August 12, 2011 - 06:39 PM
Congratulations on the new work area. More is definitely better!
#14 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted August 12, 2011 - 07:22 PM
Congrats you will LOVE the extra space, And it will be FULL before you know it.
#15 MH81 OFFLINE
Posted August 12, 2011 - 07:25 PM
Mark each piece???
Where's your sense of adventure, man?
Just kidding, good plan. Can't wait for the pics.
