312 vibration problems
19 replies to this topic
#16 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 17, 2011 - 08:30 AM
I got away with just replacing the back 2 on mine. I'm sure the front ones aren't 100% and I will probably replace them later. I already put over 500$ in parts into it. I'm sure it will be a lot smoother. One thing is to make sure that the idle is set properly. Believe it or not the correct setting is 22-2400 rpm's. If it is idled down realy low it will vibrate, even with new mounts.
#17 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 18, 2011 - 01:05 PM
All back together mowed about 3 hours on it. Running very good. Now I'm looking to put a plow on it. The bad thing is I don't have front hydraulics. So more work more money but also more fun.
#18 MH81 OFFLINE
Posted August 18, 2011 - 01:33 PM
Glad to hear it's OK. Sounds like you got yourself a nice tractor.
BTW, the next logical step to your progression of more work, more money, more fun is...
MORE TRACTORS!!!
#19 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 18, 2011 - 02:50 PM
Yes that's true I got 3 more lined up just working on prices. 1 is a 66 Jd 110 then a 67 Jd 112 last is a cub.
#20 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 18, 2011 - 05:41 PM
Excellent! - The transformation is complete!
