312 vibration problems
19 replies to this topic
#1 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 10, 2011 - 06:58 AM
Is it common for 300's to vibrate bad. I've seen it listed in other threads also talked to a guy out by me and he said did also. I thought it was just me.
#2 MH81 OFFLINE
  • 29,978 Thanks
Posted August 10, 2011 - 07:10 AM
Does it only do it when your mowing, or is this a constant thing?
#3 buck50bmg OFFLINE
buck50bmg
  • 1 Thanks
  • 37 posts
Posted August 10, 2011 - 07:20 AM
Is it at a certain speed? Panels on securely?
#4 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 10, 2011 - 07:43 AM
All the time. Yes all panels tight. I'm changing motor mounts & isolators on drive shaft. Someone had taken the Jd rubber mount off plus added a 2 inch angle iron to the front mount. If anyone would have pictures of what front mount is suppose to look like. I don't no what else I'll find. But I only paid $ 50 for tractor.
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 10, 2011 - 08:08 AM
If even 1 of your motor mounts are defective then you will get a lot of vibration. Here's the best I can do for pictures right now. The first one is of the rear mount after I had repaired the frame and was test fitting a new mount. In the second picture you can see the front mounts. Have a look at the parts diagrams to make sure you have all the mounting brackets. If you post some pictures it will be easier to see what was done.
#6 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 10, 2011 - 12:42 PM
Thanks that helps alot. I would send pics but I can't figure out how to do it. From my iPhone
#7 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 10, 2011 - 01:02 PM
I can get better pictures for you if you need them. Let us know how you're making out with it.
#8 grnspot110 ONLINE
grnspot110
  • 4,323 Thanks
  • 2,696 posts
Posted August 10, 2011 - 05:02 PM
My 314 does a t low end throttle, 300 I tried also! I've been told by a small engine mechanic this is normal if they smooth out with speed increase. "JD bought the engines without balance gears & the rubber "isolators" are to absorb the vibration at low end". ~~ grnspot
  • JDBrian said thank you
#9 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 10, 2011 - 06:24 PM
I didn't realize that the Kohlers in the JD's didn't have the balancer. I checked the parts diagrams and there is no reference to the balancer. I guess that explains the rough running at low speed. If I remember correctly the low idle speed on my 314, according to the owners manual, is 2100-2300 rpms. The lack of the balancer explains this high speed. Thanks for this info. On the + side you don't need to worry about the balancer breaking and destroying the motor. I guess that can happen to these engines when they get a lot of hours on them.
#10 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 15, 2011 - 08:38 PM
Some pictures of what they did. The rubber u see in picture is what I tried first before getting real mount from Jd
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 16, 2011 - 10:09 AM
They made a real mess of it for sure. Good luck getting it sorted out. The mounts are a real problem area on most 25+ year old tractors.
#12 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 16, 2011 - 10:14 AM
I just got a look at a service manual for the 300, 316, 312,314. The original 300 had the balancers but none of the other engines have them. That makes me feel a bit better about mine being rough at low speed. The other thing is that the low speed idle setting for a 314 is 2200-2400 rpm's so they should not be running at a slow idle if set up to factory spec.
#13 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 16, 2011 - 11:57 AM
Got new mounts put on. Can't wait till I get motor back in.
#14 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 16, 2011 - 06:41 PM
That looks good. Did you get the mounts from JD?
#15 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 16, 2011 - 10:06 PM
Yes $140 but should help alot. It's killing me not to be out working on it but I guess that 9-5 has to come first. But Thursday I should be home so hoping to get it back together.
