* * * * * 1 votes
Custom 3 Point Hitch by Keith
258 replies to this topic
#256 hondacivic247 OFFLINE
hondacivic247
  • 7 Thanks
  • 26 posts
Posted November 19, 2015 - 06:00 AM
I want to do the same make a 540 pto I think it could be possible with different pulleys sense his uses 2 you would need to create a gear reduction with them to lower the rpm speed. Which would need larger pulleys to be used. I've done it on my compressor that the motor spins 3000+ rpm but just use the right pulleys and I got it down to 945 rpms
#257 skyrydr2 OFFLINE
  • 3,625 Thanks
  • 3,277 posts
Posted November 19, 2015 - 08:08 AM
That's fine if you can make the right angle gear box work . you will need to drop multiple times to get to 540. Then you need to get the splined shaft. Then it must be mounted some rugged!!
#258 skyrydr2 OFFLINE
  • 3,625 Thanks
  • 3,277 posts
Posted November 19, 2015 - 06:55 PM
Here are a few shots of my 3 point hitch today. And some shot of the front pto installation.
  • Rock farmer said thank you
#259 skyrydr2 OFFLINE
  • 3,625 Thanks
  • 3,277 posts
Posted March 15, 2016 - 05:32 PM
Bump to front for pto help.
  • michael.kitko and Heffalump have said thanks
