reverse tractor boom
10 replies to this topic
#1 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted August 08, 2011 - 09:11 PM
This post is mostly for MH81, who is featuring his boom and Sears tractor for next month. Sometime you get to use the boom and sometimes the boom come for you.600+lift.jpg
#2 caseguy OFFLINE
  • 1,629 Thanks
Posted August 08, 2011 - 09:35 PM
Either way, it's great to have one when you need it! Thanks for the pic!
#3 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted August 08, 2011 - 09:47 PM
Well if you have ever owned one of the hand clutch suburban, the first thing you learn is: if it dont run you aint going to move it. This happened a couple of yrs back. I started plowing, made a couple of rounds and the engine locked up. So what else could i do but throw the engine hoist up on an old truck frame, and lift it out of the garden. The engine as it turned out, went bad because the wrong rings were installed by the engine shop. It took several months of soaking it, the piston came out, the motor was saved. This is my favorite plowing tractor.
#4 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted August 08, 2011 - 10:23 PM
Sometime you do what you got to do. Sure proud you got her going again.
#5 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,167 posts
Posted August 08, 2011 - 10:29 PM
There is times i would like that for myself lol.
#6 MH81 OFFLINE
Posted August 09, 2011 - 12:18 AM
Thanks for the pictures.
Glad shes back. They are nice to plow with, aren't they?
#7 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted August 09, 2011 - 01:22 PM
I can push my 65 backwords. But forget pushing it forwards.
#8 IamSherwood OFFLINE
  • 8,395 Thanks
Posted August 09, 2011 - 02:02 PM
There's always a way to get it done.:thumbs:
Am I seeing right? You chained it to the seat mount?
Must have North American bolts that are strong enough to hold.
#9 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted August 09, 2011 - 02:21 PM
looks like its to the seat and the steering wheel.
#10 olcowhand ONLINE
  • 42,469 Thanks
  • 31,825 posts
Posted August 09, 2011 - 03:03 PM
Back when I had my DB Burban, I could push it a couple feet, then I was worn out! And that was when I was lots tougher! Other than the "no moving w/out power" I loved the drive system, as it was quite unique. Reverse was kinda weak though, especially if it started raining!
#11 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted August 09, 2011 - 07:26 PM
You know i looked at the lift this way: the hitch is made out of the same stuff the seat spring is and bolted down with the same number and size bolts. Because the fronts heavy i ran up though the steering to balance it out. Since i have several tractors i wasnt worried much about damaged parts.
