Wood chipper on the Bolens 1053
24 replies to this topic
#1 NUTNDUN OFFLINE
  • 10457 Thanks
  • 15622 posts
Posted August 07, 2011 - 07:47 PM
Dad bought a wood chipper and a Brinly dump cart for his Bolens. The Brinly dump cart though I think is actually for a Cub Cadet. The wood chipper though is definitely for the Bolens. We got it mounted but we need a longer female u-joint to be able to hook it up to the pto.
We parked it in the work bay of the garage because I have a little work to do on the belt cover. Would be really cool to get the u-joint and have it hooked up for the show but I don't know if that will happen or not. It definitely isn't going to be the easiest to get on the trailer with it mounted either, will have to use my other ramp on top of the trailer ramps to eliminate some of the steepness.
Here are some pics, would love to hear some input as far as the pto shaft, did Bolens make a longer female one specially for this? I have a feeling we might be making our own adapter.
Would also like to get some opinions or confirmation on the Brinly dump cart.
#2 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted August 07, 2011 - 07:51 PM
The Chipper looks to be in great Shape!
That dump is definitely for the Bolens.
I'll do some searching and see what the part number was for that u joint.
#3 NUTNDUN OFFLINE
  • 10457 Thanks
  • 15622 posts
Posted August 07, 2011 - 07:52 PM
If that dump is for the Bolens, how in the heck does it hook up?
#4 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted August 07, 2011 - 07:56 PM
Thats exactly what I said when I got mine. LOL
You will need to use the long pins for the tiller and attach them to the rear mounting tabs. Then put a bolt through the hole in the middle which attaches to the rear hitch.
I'll get some pictures for you
#5 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted August 07, 2011 - 08:01 PM
Longer 1x1 stock for the shaft?
#6 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted August 07, 2011 - 08:02 PM
  • grand said thank you
#7 NUTNDUN OFFLINE
  • 10457 Thanks
  • 15622 posts
Posted August 07, 2011 - 08:28 PM
That makes sense now Brian. Thanks for posting the pics. Now he just needs to decide what tractor to put it on. Could put it on the back of the 1053 to go along with the wood chipper and maybe even a chainsaw for display.
#8 NUTNDUN OFFLINE
  • 10457 Thanks
  • 15622 posts
Posted August 07, 2011 - 08:30 PM
The only problem is the shaft isn't square, it is a rectangle. I could get square stock and have it milled down and get a piece to wrap around it like a sleeve and weld it all together.
#9 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted August 07, 2011 - 08:52 PM
http://www.baumhydra...talog/sec-p.pdf
Here's some but not sure if it's what your looking for , Al
#10 daytime dave OFFLINE
  • 5495 Thanks
  • 6782 posts
Posted August 07, 2011 - 10:39 PM
Great looking attachment. Hope you get the parts worked out soon. Dump cart is nice too. Your dad did well.
#11 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted August 07, 2011 - 11:39 PM
Nice find!! and I do like the idea with the chainsaw,dump cart, chipper!!
#12 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted August 07, 2011 - 11:56 PM
you beat me to them.. they were on reading craigslist
#13 KennyP ONLINE
  • 53241 Thanks
  • 53335 posts
Posted August 08, 2011 - 04:42 AM
Those are cool. Thought about making one of those dump thingys. I have an old small wheel barrow that needs handles whic cost more than a new wheel barrow. I've got two others that are bigger, so this one sits. Need to see how they set up the frame work under it.
Edited by KennyP, August 08, 2011 - 05:41 AM.
#14 NUTNDUN OFFLINE
  • 10457 Thanks
  • 15622 posts
Posted August 08, 2011 - 05:20 AM
Yes I they were on craigslist, it was a couple weeks ago if not a month ago. Dad usually procrastinates to the last minute only to find the stuff gone but I think he might have been on vacation or had a couple of days off at the time and went out and got them.
#15 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5127 Thanks
  • 2912 posts
Posted August 08, 2011 - 08:36 AM
The manual for the MacKissac shredder is in the Manuals forum, as well as the info for the Brinly BB10 dump cart (you probably know that). .....It appears MacKissac provided the longer PTO joint, not Bolens, as it has a MacKissac part number shown in the manual.
MacKissac is still in business, as far as I know, and they may possibly have what you need.
A minor point, but don't consider that unit a "chipper." .....It was based on the MacKissac Model 9P Shredder, and rated as having a capacity of up to 1-1/2" branches. ......It does not produce chips, but instead shreds the material. .....The screen at the bottom controls the size of the shreddings. .....Various screens are still available for these units.
The MacKissac Model 12P was a similar unit with the addition of a side hopper and chipping knife to handle branches up to 3-1/2".
  • NUTNDUN, Bolens 1000, grand and 2 others have said thanks
