72 Jd 110 wiring problems
8 replies to this topic
#1 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 06, 2011 - 09:59 PM
It has a k241as motor the guy I got it from cut the wires up nothing to amp meter new key switch but not Jd I'm headed to Jd dealer to get parts but a wiring diagram would help. Thanks
#2 Green216 OFFLINE
Green216
  • 8 posts
Posted August 07, 2011 - 05:50 AM
If you go to the manuals tab on this site, select Tractor and Implement Manuals, select John Deere and then tractor manuals you will find a wiring diagram for the 110 that you can download. Good luck!
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 07, 2011 - 05:59 AM
Welcome to the forum. Let us know if you need any more help on getting the wiring sorted out. It is a common problem on these older tractors. People consider them worthless and won't spend a cent on them. They hack up the wiring doing a lot of damage to save a couple dollars. I had to redo most of the wiring on my 314 when I got it.
#4 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 07, 2011 - 08:18 AM
Thanks I tried but when I opened the file it was all just letters & symbols would not open. Any other ideas?
#5 Green216 OFFLINE
Green216
  • 8 posts
Posted August 07, 2011 - 01:50 PM
The download is a .pdf file so you need Adobe Reader to view it. You can download adobe reader for free from here. http://get.adobe.com/reader/
If you don't want to go that route, the pic below is it. Just right click it and do a "save as" and then you can open the saved file via any picture viewer or Microsoft paint. It will be much clearer if you download Adobe and view it that way though. I hope this helps.....
Edited by Green216, August 07, 2011 - 01:56 PM.
forgot to insert as hyperlink
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 07, 2011 - 03:31 PM
It sounds like you may be using a Mac. If so, then you need to rename the file by removing the .html from the end of the filename. This is a problem that will be fixed when the forum moves to new software in the near future.
Edited by JDBrian, August 08, 2011 - 04:17 AM.
#7 Green216 OFFLINE
Green216
  • 8 posts
Posted August 07, 2011 - 03:38 PM
I wasn't aware of the Mac issue, good to know thanks.
#8 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 07, 2011 - 03:48 PM
Yes, I use a MAC and it bit me as well. It was only discovered a few weeks ago. The rename is an easy fix for now.
#9 fishman OFFLINE
fishman
  • 19 Thanks
  • 130 posts
Posted August 07, 2011 - 05:03 PM
Yes thanks for the pics. I am using Mac
