* * * * - 6 votes
I beat Kenny on this morning.
11174 replies to this topic
#6586 Alc ONLINE
  • 7,257 Thanks
  • 7,595 posts
Posted June 15, 2015 - 07:42 AM
Hot and sticky here too . Remember a few weeks ago when I thought my plants where going to be damaged because it was in the 30s lol
  • toppop52 said thank you
#6587 toppop52 OFFLINE
toppop52
  • 5,547 Thanks
  • 4,907 posts
Posted June 15, 2015 - 08:00 AM
We had a couple of light frosts after I put my flowers out in April, distant memory now!
#6588 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted June 15, 2015 - 12:15 PM
It's getting to be a rain forest around here. Just got over 3/4" in less that an hour. Be glad when monsoon season is over so I can do a few things.
#6589 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,186 Thanks
  • 2,942 posts
Posted June 16, 2015 - 04:15 AM
69 here this morning, supposed to go up to 79, chance of rain too
#6590 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted June 16, 2015 - 05:13 AM
Morning All! 72° (22C) this morning and calm winds. 83° (29C) for a high with 80% chance of afternoon showers.
#6591 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,276 Thanks
  • 6,080 posts
Posted June 16, 2015 - 06:07 AM
MORE FLOODING!!  Just what we need!!!
This shyt is getting old!!   :wallbanging:  :wallbanging:  :wallbanging:
Looks like a day in the shop working on the neighbor's JD 455.  I feel like crap because I talked him into getting the thing and it is a screwed up mess since he got it!!  The deck lift linkage is all wrong, the PO eliminated the seat sw. and now the thing won't stay running..  Tires are going flat..  ARGGGGHHHHHHH!!  I'll make it right today & tube the tire..   :wallbanging:  :wallbanging:
#6592 toppop52 OFFLINE
toppop52
  • 5,547 Thanks
  • 4,907 posts
Posted June 16, 2015 - 06:24 AM
76° now, humid as a sauna outside, going to 95° they say, with high humidity. Now they're saying it's going to be a little cooler for a couple of days after today. I hope so.
#6593 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 16, 2015 - 07:13 AM
81 this morning with a forecast high of 101. No rain in sight.
#6594 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,276 Thanks
  • 6,080 posts
Posted June 16, 2015 - 08:26 AM
  • jimbobbillyray said thank you
#6595 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,186 Thanks
  • 2,942 posts
Posted June 17, 2015 - 04:06 AM
73 out side this morning, more rain in sight.  'Bill' should arrive in a few days....
#6596 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 17, 2015 - 05:02 AM
Morning guys. Rain last night but clear this morning. Nice summer day out there but a bit cooler than normal with highs about 65f. Black flies are tapering off now but mosquitoes are on the rise.
#6597 KennyP ONLINE
  • 40,986 Thanks
  • 47,152 posts
Posted June 17, 2015 - 05:17 AM
Morning Brian & All! It's 72° (22C) and damp out there. High will reach around 82° (28C) with more rain.
#6598 toppop52 OFFLINE
toppop52
  • 5,547 Thanks
  • 4,907 posts
Posted June 17, 2015 - 06:30 AM
Got a little shower yesterday afternoon, but it broke the heat, 95° before the rain, 83° after, but still humid as heck. 75° now, low 80's today, 80's for 3-4 days, then 11 straight days predicted over 90°.
#6599 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,276 Thanks
  • 6,080 posts
Posted June 17, 2015 - 07:04 AM
Partly sunny or partly cloudy..  Whichever..  79° for a high..
Worked on the 455 nearly all day yesterday..
Flat tire tubed after removing the nasty, crappy, slimy, gunky FIX-A-FLAT from the inside of the tire and off the rim.  It took a whole roll of paper towels!!  I told the owner that if he ever uses that stuff I'll never fix another tire for him again!  BLEEEEAAAAAACCCCCHHHHHHHH!!!!   :mad2:
Next was the deck..  It would not lift for some reason..  Examined the lifting arm action and the arms were out of proper alignment..  Took off the seat & foot pans and removed & re positioned the lift arms.  Once done, a total re-leveling of the deck ensued..
Steering-  noticed many loose fittings and a few bad tie rod ends.  Sent the owner shopping and after he returned with parts we installed them.  The right one fell apart during removal..  Whew..
Starting problem-  After pringting out & reading the power circuit diagnosis section I found a dirty connection on power module was the trouble along with the shoddy work the PO's so called mechanic had done..  The P/M card was not even fastened to the tractor securely.  I tightened all 4 screws and cleaned connectors.  Found out later that the owner has been washing the side panels off with the hose..  I showed him why that is a big no-no..  Water & electrical parts=baaaaadddd..
Front steering arm plate was loose we tightened it up and installed a wider shim to tighten the steering up more better..
That was enough fun for the day so I then broke out the 4310 and put the driveway back where it belonged after the torrential rains we've been getting..  All good till next time!!   :shoot2:
Asa today will be nicer I'm off to snake a pond drain with a buddy..  The fun never ends!!  Back to work tomorrow..  Yea!!
#6600 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted June 17, 2015 - 09:42 AM
93 here already. Gonna be another scorcher.
