More trouble with 314 hydro linkage
9 replies to this topic
#1 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 05, 2011 - 05:30 PM
I got the tractor back together and took it for a test drive today. I had a problem with hydro creep. I replaced the spring for the neutral detent lever and adjusted it. When I took it out in the yard I noticed that the tractor would slow down a lot on hills and when you went to slow down it would suddenly stop with a jerk when you were near neutral.
I remembered that there was a lot of slop in the linkage where it connects to the lever at the hydro. I thought it would be OK but not so. The new neutral spring was causing the hydro to snap into neutral whenever the lever was close. So, how to fix it. Below is a picture of the linkage. It's a real contraption for sure.
The problem was wear of the hole in part 24 and the yoke 21. I found that the 3/8" hole in part 24 would take a 7/16" bolt due to wear. I removed yoke 21 and drilled it out to 7/16" and made a new pin to match. Due to tight spacing the pin is flush with the outside edge of the yoke and is secured with a cotter pin in the middle of the yoke. After I put it all back together the neutral would not adjust and I had to adjust the nut on the yoke to get it to come into range.
A quick test drive and the lurching is gone and it climbs hills now without slowing down. Heres a couple of pictures of the new pin and re drilled yoke.
  • larryd said thank you
#2 KennyP ONLINE
  • 40,004 Thanks
  • 46,714 posts
Posted August 05, 2011 - 06:30 PM
Cool fix. Glad you got it figured out and repaired. Thanks for the pics.
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 05, 2011 - 07:05 PM
It seems that everything on this tractor is worn out. I just keep finding more problems. To replace the worn out parts would not be an easy job and I don't even know if the hydro lever part 24 is still available. This was a cheap fix but I did have to spend a couple of hours under the tractor and making the new pin. I wonder what will bust next! The engine still isn't running right. It's missing and stumbling intermittently. I'll see what I can find on that tomorrow.
#4 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted August 05, 2011 - 09:35 PM
Glad you were able to fix it with a little ingenuity. Before you know it, the John Deere 314 will be just like new :D
#5 MH81 OFFLINE
Posted August 06, 2011 - 12:15 AM
Brian, glad you got this problem solved. The "Whats next?" scenario is one I am familiar with, part of the fun isn't it? :p
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 06, 2011 - 05:36 AM
Sorry for sounding negative! Yes, it's all part of the fun. I enjoy problem solving. This project has just taken a lot more of my time than I had planned. I have a lot of yard work to do, landscaping and such. I am about to switch to doing that and give the 2320 a workout. I need the 314 to be easy to deal with and reliable for my wife to use it. The 2320 is a bit intimidating for her.
#7 KennyP ONLINE
  • 40,004 Thanks
  • 46,714 posts
Posted August 06, 2011 - 05:51 AM
Be sure to post some pics of the upcoming projects. I would like to see that 2320 in action. And I know what you mean about getting the tractor reliable for the lady of the house. They just don't have the same feelings about our tractors.
#8 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 15, 2013 - 03:30 PM
Brian:
  You will be receiving a bill from John Deere for parts and labor in the sum of  $235.00. Thank you  for your service.
Dick
#9 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted February 27, 2013 - 02:39 PM
While I have  myJD314 apart for painting I have found a few things also. Just some sloppy parts here and their but all fixable as you say.
larryd
#10 Trav1s OFFLINE
Trav1s
  • 3,509 Thanks
  • 4,491 posts
Posted February 27, 2013 - 03:26 PM
Should this be stickied?
