Haban sickle bar mower.
19 replies to this topic
#16 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted August 30, 2011 - 01:51 AM
The Haban data base file I have says that the 405 fits the 600, 800, & 900. I'm pretty sure that it would fit most of the tube frames though.
There is also a 405A. The same data base says it fits the 856. 1053, 1253, and 1257. I have my 414/405A mounted on a G10 (1055) with no problem.
The big difference between the two is that the 405 is belt driven from the tractor, while the 405A is PTO driven. There are other differences as well, but that is the most obvious.
#17 AdrianR OFFLINE
AdrianR
  • 8 Thanks
  • 17 posts
Posted September 02, 2011 - 10:13 PM
could someone post the haben 415 and 415a manuals to the stickies manual section
#18 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted September 03, 2011 - 12:29 AM
Just join this YAHOO site, and you can get both of them:
Haban : Haban Tractor Accessories
#19 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted September 03, 2011 - 07:20 PM
the tube fame sickle is a 405a
#20 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted September 03, 2011 - 07:32 PM
[quote name='cowboyarenas']Hi, I have a haban sickle mower # 405, and I want find a tractor to make it work, but I dont know what tractor, I read about them nd they say for bolens, so i bought a bolens qs 16, and did not work, please help me out, what tractor do i need, it says model 405 and serial 184113 B
if its a 405a you will have to get a bolens tube frame.. a qs 16 is a newer machine an it will not work. you will need a bolens 850, 1050, 853, 1053, 1054, 1253, 1254, 1256, 1220 or 1225. there might be a few other tube frames but there the models i can think of off the top of my head. you should get atlesast a 1000 or 1050 you want 10hp to run it smoothly if its a 405 not a 405a it will fit bolens 800, 900, 1000. there pretty much the same tractors but the regular 405 came with the first gen tube frames and run off a belt rather then a p.t.o shaft.
Edited by 1967bolens collector, September 03, 2011 - 07:47 PM.
  • Bolens 1000 said thank you
