Air Compressor Project
7 replies to this topic
#1 RustyTub OFFLINE
RustyTub
  • 26 Thanks
  • 137 posts
Posted August 03, 2011 - 03:18 PM
So I found this used gas powered air compressor. This local company bought a service truck and wanted a on board air compressor so the seller threw this in to make it a better deal. well there mechanic said it was a POS and to off it. so i bought it for 50 bucks. (not to mention after talking with the owner for about an hour he insisted on me emailing him my resume)
But any way here it is, A Champion 4 cyl, two stage pump with a V twin gas powered engine. here is a link to the pump specs.
Champion Air Compressor Products
I know nothing about its condition or any specs on the engine I have only owned it for about 16 hours. all of which I have been at work.
I want to add my 100 gallon tank to this and build it on a trailer frame, something small that my GT can tow it around the property. Or for a bigger job throw it behind my truck and tow it to a job site. But for 50 bucks I couldnt pass it up.
#2 KennyP ONLINE
  • 37,389 Thanks
  • 45,445 posts
Posted August 03, 2011 - 04:14 PM
Jonathon, I hope it works for you. For $50, you can't go too wrong. Plus, you might get a job out of the deal. Good luck with it all!
#3 RustyTub OFFLINE
RustyTub
  • 26 Thanks
  • 137 posts
Posted August 04, 2011 - 12:18 AM
So today I found out that this is a honda gx 670 taf engine with 24 hp I got it to turn over but no spark time to get dirty and diag this thing
#4 KennyP ONLINE
  • 37,389 Thanks
  • 45,445 posts
Posted August 04, 2011 - 04:44 AM
From the compressor specs, I'd say you are a bit over powered. Hope you can get the engine running without too much trouble. Should make a great compressor for your needs.
#5 RustyTub OFFLINE
RustyTub
  • 26 Thanks
  • 137 posts
Posted August 10, 2011 - 02:31 PM
Well Got some time to Diag the no spark situation. Looked at how it had been wired up before they cut the wire harness. They had supplied the coild with 12V! They probably cut the wires when all the smoke started coming from the engine.
#6 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted August 10, 2011 - 02:39 PM
Tractor with rear PTO equals cheap power if you already have one.
#7 olcowhand ONLINE
  • 40,327 Thanks
  • 31,165 posts
Posted August 10, 2011 - 03:49 PM
WOW, what a deal!
#8 RustyTub OFFLINE
RustyTub
  • 26 Thanks
  • 137 posts
Posted August 11, 2011 - 02:14 PM
Nothing with rear PTO, But I do have one with a front pto!?!?! Ordered two new coils today should see them in about a week. Which is just fine I have too much other stuff to do right now. Gonna pull the pump off and clean it all up make this thing look all pretty.
