Need info on Plow
6 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,356 Thanks
  • 5,603 posts
Posted April 12, 2010 - 05:23 PM
Can anybody tell me about this plow?
What's missing?
How to hook up?
What's needed to hook it up?
:help:
#2 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted April 12, 2010 - 05:53 PM
That one looks like you wouldn't need a sleeve hitch if you have a way to mount the lift handle. It looks like it is all there. You would just need a pivot point on the back of the tractor and then have the lift handle bolted somewhere to raise and lower it. Where did ya find that thing? Do you know what it came off of?
#3 DH1 ONLINE
DH1
    Electric Tractors
  • 5,356 Thanks
  • 5,603 posts
Posted April 12, 2010 - 06:04 PM
This was in the 66MF10 deal, they weren't sure what it fit but assumed it was for the Massey GTs.
#4 olcowhand ONLINE
  • 42,311 Thanks
  • 31,777 posts
Posted April 13, 2010 - 04:53 PM
It's sure not for any Massey GT, that I can say for sure. What it does fit I have no clue. I would either find, or fab up a sleeve adapter for the front, then drop the turnbuckle thing. Being it has no moldboard tilting mechanism, if you fab a hitch, be sure to set it up like plowing, with both left tires on 4 or 5" blocks with the rear of the landslide 1/4 to 1/2" off the ground, with plowshare sitting flat....before you weld bracket... to have it set so she'll go in the ground.
#5 Gary Burnett OFFLINE
Gary Burnett
  • 10 Thanks
  • 98 posts
Posted April 13, 2010 - 08:38 PM
Looks like it came off an early model GT of some sort.I wouldn't screw it up as it might be worth considerable $$$ just got to find the right buyer
#6 olcowhand ONLINE
  • 42,311 Thanks
  • 31,777 posts
Posted April 14, 2010 - 05:30 PM
Not sure which, but it's either a 6 OR 8" plow, and I'm thinking built for a 2 wheel walk-behind tractor.
#7 DH1 ONLINE
DH1
    Electric Tractors
  • 5,356 Thanks
  • 5,603 posts
Posted April 14, 2010 - 06:00 PM
A friend has a Brinly that looks similar but his is setup for a sleeve hitch. There are no names or #s on this thing.???
