Getting rid of westeria
5 replies to this topic
#1 buck50bmg OFFLINE
buck50bmg
  • 1 Thanks
  • 37 posts
Posted July 31, 2011 - 06:53 AM
Anyone have a good way to kill westeria?
#2 Gibby OFFLINE
Gibby
  • 96 Thanks
  • 360 posts
Posted July 31, 2011 - 10:45 AM
napalm?
#3 ducky OFFLINE
  • 1,988 Thanks
  • 4,107 posts
Posted July 31, 2011 - 11:09 AM
Instructions
Things You'll Need
  • Pruning shears or handsaw
  • Herbicide
  • Shovel
  • 1 Dig up new, young wisteria sprouts with a small shovel or by hand. Make sure you remove the root system for the new sprouts.
  • 2 Cut the wisteria vine off at the stump. This may be challenging if the vine is matures and has been allowed to grow for quite some time, as the stump may be very large. Use pruning shears to snip the vine off at its stump, if it is small. Use a handsaw to cut off older, larger vines at their base.
  • 3 Spray an herbicide liberally on the top of the stump. Avoid getting the chemicals onto the surrounding area so other plants are not contaminated. The best time to apply herbicide is during the winter months, when the wisteria plant is dormant and less likely to resist the contaminants.
  • 4 Keep applying the herbicide daily for a few days or as necessary to ensure the plant is effectively killed. If the wisteria tries to grow again from its base, cut it again and apply more herbicide.
  • 5 Continue to be vigilant about plucking up any new sprouts as soon as they appear. Wisteria is very resilient and will most likely continue to grow unless the sprouts are removed quickly.
Read more: How to Kill a Wisteria Vine | eHow.com How to Kill a Wisteria Vine | eHow.com
#4 KennyP ONLINE
  • 40,130 Thanks
  • 46,764 posts
Posted August 01, 2011 - 04:32 AM
napalm?
That should do it!
#5 grnspot110 ONLINE
grnspot110
  • 4,286 Thanks
  • 2,682 posts
Posted August 01, 2011 - 04:59 AM
Tordon RTU!
#6 ducky OFFLINE
  • 1,988 Thanks
  • 4,107 posts
Posted August 01, 2011 - 07:54 AM
Tordon RTU!
I think that stuff was used in Vietnam. Agent White if I remember right.
