Help me for my wh, im french...
2 replies to this topic
#1 josevador OFFLINE
josevador
  • 3 posts
Posted July 29, 2011 - 04:27 PM
Hello, im jerome from france, i just buy a Wheel horse model : 1-350 serial 128312, and i m looking for some manuels to repair it.
It's hard for me navigate in the forum and make a search whith my level of english, so if u please to give me the link to doawnload it.
Thx for helping me.
#2 caseguy OFFLINE
  • 1,628 Thanks
Posted July 29, 2011 - 05:13 PM
:wave: josevador Welcome to GTTalk! I did a little digging for you, but can't find a model 1-350. I did find a model 1-0350, which is a 1973 Raider 12. There isn't a manual in our manuals section for it though. I hope that you're able to locate one. Best of luck on your restoration!
#3 MikesRJ OFFLINE
MikesRJ
    One of the 1st 500!
  • 71 Thanks
  • 118 posts
Posted July 31, 2011 - 11:06 AM
I suspect you have a model # 1-0350. The information given above is correct, and the manuals you seek are listed below.
TRACTOR INFORMATION:
Model Number 1-0350
Serial # None - None
Model Year 1973
Product Name Raider 12 8-Speed Tractor
Product Brand Wheel Horse
Product Type Riding Products
Product Series Garden Tractor, Pre '74
Swath Deck Optional
Discharge Deck Optional
Engine/Motor Manufacturer Kohler
Engine/Motor Size# 12 hp
Engine/Motor Model # K301S-47421D
Engine/Motor Type 4 Cycle
Engine Starter Electric
Transmission Manufacturer Wheel Horse
Transmission Model # 5073
Transmission Speed 8 Speed
Transmission Type Gear
MANUALS:
Operator Manual - A-5324 Owner's Manual
Parts Catalog - A-5343 Parts Catalog
Wheel Horse 6 & 8-Speed Mechanical Transmission - 492-4004 Transmission Manual
Model/Part# Description Comments
5-0621 36" Mower (Rear Discharge) N.L.A. Original Model Supersedes To: 5-0622
5-0721 36" Mower (Side Discharge) Current Model Available: 05-36MR05/78305 Original Model Supersedes To: 5-0722
5-1010 42" Mower (Side Discharge) Current Model Available: 15-42SC03/78345 Original Model Supersedes To: 5-1011
5-1210 48" Mower (Side Discharge) Current Model Available: 15-48SC03/78361 Original Model Supersedes To: 5-1211
6-0200 32" Snow Thrower (Only)(Requires 6-9112) Requires replacing 102729 with 107403 and 102743 with 9750. N.L.A. Original Model Supersedes To: 6-0202
6-4113 Completing Package for 6-9622 & 6-9612 N.L.A. Original Model Supersedes To: 6-4114
6-6212 37" Snow Thrower (Only)(Requires 6-9112 or 6-9122) N.L.A. Original Model Supersedes To: 6-6213
6-9113 Completing Pkg. (Required with 6-0200 & 6-6212) N.L.A.
6-9622 42" Dozer Blade (Only)(Requires6-4113) N.L.A.
7-1112 40" Mid-Mount Blade N.L.A. Original Model Supersedes To: 7-1113
7-1211 36" Tiller N.L.A. Original Model Supersedes To: 7-1252
7-1251 36" Tiller Current Model Available: 07-36TL05/79370 (Requires Service Assembly 105105 - N.L.A.) Original Model Supersedes To: 7-1252
7-1312 50" Sickle Bar N.L.A.
7-1321 42" Sickle Bar N.L.A.
7-1512 32" Disc N.L.A. Original Model Supersedes To: 7-1513
7-1611 Spike Tooth Harrow N.L.A. Original Model Supersedes To: 7-1612
7-1722 Cultivator (Requires 8-5511 or 8-5521) N.L.A. Original Model Supersedes To: 7-1723
7-2111 Utility Wagon N.L.A. Original Model Supersedes To: 7-2112
7-2211 Dump Trailer N.L.A. Original Model Supersedes To: 7-2212
7-2311 32"Lawn Roller N.L.A. Original Model Supersedes To: 7-2312
7-2411 36" Aerator N.L.A. Original Model Supersedes To: 7-2412
7-2512 31" Lawn Sweeper N.L.A. Original Model Supersedes To: 7-2513
7-2521 38" Lawn Sweeper N.L.A. Original Model Supersedes To: 7-2522
7-2611 Lawn Vacuum N.L.A. Original Model Supersedes To: 7-2612
7-2621 Nozzle Accessory use w/7-2611 N.L.A.
8-0221 Extension Side Plates for 6-0100 & 6-6212 N.L.A.
8-0512 Chrome Wheel Disc N.L.A.
8-0731 Dual Wheel Kit N.L.A.
8-1111 Wheel Weight (rear) Set Current Model Available: 81115 Original Model Supersedes To: 8-1112
8-1211 Wheel Weight (front) Set Current Model Available: 81214 Original Model Supersedes To: 8-1212
8-2511 Tire Chains (Pair) N.L.A.
8-2801 Cleat Tire Set (23 x 8.50-12) N.L.A. Original Model Supersedes To: 8-2841 (Tire Only)
8-3513 Electric P.T.O. (1 1/8" Dia.) N.L.A.
8-4221 Electric Lift N.L.A. Original Model Supersedes To: 8-4222
8-4311 Spring Assist Lift N.L.A.
8-5511 Clevis Hitch Current Model Available: 85518 (Requires Service Assembly 105104 - N.L.A.) Original Model Supersedes To: 8-5512
8-5521 Slot Hitch N.L.A. Original Model Supersedes To: 8-5522
8-6721 Soft-Ride Seat Kit N.L.A.
  • MH81 and caseguy have said thanks
