new with 2a016 engine questions
66 replies to this topic
#46 olcowhand ONLINE
  • 43,153 Thanks
  • 32,007 posts
Posted August 28, 2011 - 02:25 PM
Looks like that ought to work just fine!
#47 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted August 29, 2011 - 08:42 PM
works great, passed the test on the mower in heavy grass, used ear muffs (oh my god is it loud!), i set the governor to suck a little more air and gas then the original one did and tuning it to the engine was easier then i thought, governor rod itself and the trottle rod from the onan genny are adjustable and the governor linkage itself is what lets in a little more gas then before by being a 3/16 longer, the governor has a very short travel but is sharp not sluggish, with the new linkage, carter N carb., and open pipe it can take on much more then before, i think it will blow some snow this winter,
the new cap over were the hose use to be is working well keeping oil in and water out, the hotter plugs i ordered are working better then the original type of plugs, made for the 4A032 engine,
Carburator : Model N Carter, 20 mm, along with governor throttle rod
Governor linkage : Model N Carter float linkage off the air filter elbow
Governor Rod : original to engine, bent outwards to line up with linkage
Carb. Adapter : 3/4 inch thick aluminum with 2 counter sunk holes, drilled and milled by my brother
Throttle Cable Bracket : also intake manufold strengthing brackets (just in case) 14 gauge mild steel sheet bent over the manifold
Governor Bracket : 14 gauge mild steel, twisted, mounts to carburator
Header Pipes : loud
Collector Pipe : still loud
#48 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted August 31, 2011 - 06:05 PM
Belt drive pully with attached rope started pully is welded up and painted,
#49 olcowhand ONLINE
  • 43,153 Thanks
  • 32,007 posts
Posted August 31, 2011 - 06:09 PM
But isn't that cranking it in the wrong direction?----- Went to double check on mine, and yes, you'll need to cut another set of slots angling the other way. Easy enough to have that happen. That is unless somehow your pics came through as mirror images.
Edited by olcowhand, August 31, 2011 - 06:26 PM.
  • trowel said thank you
#50 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted August 31, 2011 - 06:38 PM
Dang it !,
i was hoping someone would not notice it, after i posted the pic.s i looked at them and :wallbanging::wallbanging::bash: i cut the slots the WRONG WAY :shoot3::shoot2:
after all that work carfully centering everything :brain_fart: when i cut the slots,
man ! i could of gotten away with it and fixed it lator,
#51 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted August 31, 2011 - 06:41 PM
i can cheat and set the grinder at a different angle and re-grind the slots a little bigger and deeper,
olcowhand, good eyes :worshippy2:
#52 KennyP ONLINE
  • 41,468 Thanks
  • 47,399 posts
Posted August 31, 2011 - 06:54 PM
You're not the first to have done something like that. And you won't be the last. Lots of meat there to correct it.
#53 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted August 31, 2011 - 07:08 PM
:smile1:
#54 olcowhand ONLINE
  • 43,153 Thanks
  • 32,007 posts
Posted August 31, 2011 - 07:11 PM
Just cut another correct set of slots & call it a "universal" rope start pulley! :D
#55 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted August 31, 2011 - 07:49 PM
not a bad idear, i would love to watch someone try and start this engine with the 4 slots, lol, or me on a bad day lol,
#56 olcowhand ONLINE
  • 43,153 Thanks
  • 32,007 posts
Posted August 31, 2011 - 07:58 PM
Color code the slots!
#57 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted August 31, 2011 - 08:21 PM
4;30 in the morning in the winter, snowing like hell, wind is blowing hard, dark as sin, i stumble out the frount door, make my way to the snowblower with a flash light,open the door and.....................:confuse: which direction is the red slots for again ?.....:bigrofl:
#58 olcowhand ONLINE
  • 43,153 Thanks
  • 32,007 posts
Posted August 31, 2011 - 09:04 PM
Left is right, right is wrong! LOL
#59 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted August 31, 2011 - 09:14 PM
:Dright is left and wrong is right....ok i got it figured out!
kind of like putting on boots early in the morning...uh...more coffee please, lol,
#60 olcowhand ONLINE
  • 43,153 Thanks
  • 32,007 posts
Posted August 31, 2011 - 09:19 PM
Now you got it! :bigrofl:
