new with 2a016 engine questions
66 replies to this topic
#31 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 05, 2011 - 06:36 AM
wow, i talk alot !
ok back to questions if you all don't mind, while i wait for the carb. adapter i was thinking of polishing the aluminum intake manifold, i can't get inside with a dremel tool, what can i polish the insides with without killing my wallet and wearing the aluminum walls too thin, bead blasting ? sand blasting with walnut shells ?
thanks
#32 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted August 05, 2011 - 09:49 AM
If polishing is all you want to do, then you might want to try soda blasting.
#33 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 05, 2011 - 04:13 PM
ok,
#34 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 09, 2011 - 04:50 PM
i was on the net reading up on porting and polishing heads, i have done chevy v-8 engines and briggs flat heads, but never a semi hemi head, while looking for a machine shop around me to shave the heads i stumbled across a motorcycle forum which talks about porting heads and one person ported twin cylinder semi hemi heads and loss 5 hp,
i know that semi hemi heads are offered to lower compresstion and burn fuel better in some engines,
anyone with experience dealing with semi hemi heads please comment,
thanks,
trowel
#35 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 09, 2011 - 06:31 PM
ah, never mind the question, it was answered, thanks for looking,
#36 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted August 09, 2011 - 06:35 PM
What was the answer?
#37 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 09, 2011 - 06:50 PM
the heads the guy messed up was a little different from mines, it was semi hemi with a deck, he smoothed out the deck (squish area), the lack of a good sharp squish results in somewhat of a 45 degree advance timing to work and needs a high dome piston to make up the difference meaning having to mill out the reminding rounded deck, my engine's heads don't have the deck and comes with high dome pistons, just a valve job and grinding of the valve lip is needed with polishing of the exhaust (how i usally do heads), i don't like to go crazy with porting,
this is what my heads look like, if only it really was true hemi heads,
#38 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 18, 2011 - 06:51 PM
here is were i am with the engine right now, progress is slow,
made aluminum carb. adapter and a temporary test govenor linkage,
#39 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 20, 2011 - 05:46 AM
i think i understand why my posting of this engine has not gotten much attention now, that's ok, i understand now, don't worry, i'll keep posting the progress,
#40 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 20, 2011 - 06:09 AM
and no im not upset or fustrated, (i was for a while) i went back and read all my posts in all the other forums and saw a pattern, im on my own with this unique engine, LOL, when im done with it i should be able to help anyone with hard question regarding this engine, feel free to ask, i enjoy helping others :smile1:
#41 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted August 20, 2011 - 06:49 AM
Yes, this is a unique engine, & very few out there own one. The 4AO32 on my backhoe has a problematic carb also, as well as my 2AO16. I may end up dropping a Kohler into my backhoe, then tinkering with the 4AO engine, possibly a carb retrofit like you're working on.
#42 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 20, 2011 - 07:21 PM
ok, i'll be more then happy to provide the data/info. that's needed,
#43 KennyP ONLINE
  • 37,426 Thanks
  • 45,465 posts
Posted August 20, 2011 - 07:39 PM
Trowel, thanks for posting on this engine. I guess they a more unusual than I thought. I've been reading (lurking) along as you go, trying to understand what you are up against. Keep it going, you never know when a new member may come up with one of these. Heck, I may find one myself. At least I know what it looks like now.
#44 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 21, 2011 - 08:05 PM
please ask any questions at any time, i'll try my best to provide the best i can give regarding this particular engine and it's brothers and sisters,
in case any one is looking for an older military onan twin cylinder genny the seller has offered it to me for $120.00, comes with engine gasket kits and parts, his email is jeepm38a11954@gmail.com,
Onan Military Generator 2 cyl
#45 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 28, 2011 - 12:25 PM
New governor linkages is made and tuned to the carb., still need to do something with the trottle cable spring,
