Cub Cadet 107
7 replies to this topic
#1 Rocking416 OFFLINE
Rocking416
  • 76 Thanks
  • 191 posts
Posted July 24, 2011 - 06:00 PM
Back in 08 i traded a Running and working MTD yard machines for a Non running or moving 1970 Cub Cadet 107 people thought i was nuts This tractor had flat tires had sat in the barn i dont even know how long and looked like a mess. Well couple years later after working on it peice by peice She is running I Re wired it Completly New keyswitch, Voltage Regulator, Valve job, Head Gasket, I even installed a Ciggarette lighter so i can charge my cell phone well im cruiseing at the tractor show. Well here she is ready to go to the show just needs some paint
#2 Bolens 1000 OFFLINE
  • 15,280 Thanks
  • 18,232 posts
Posted July 24, 2011 - 06:24 PM
Nice Looking machine! :bounce:
  • Rocking416 said thank you
#3 Rocking416 OFFLINE
Rocking416
  • 76 Thanks
  • 191 posts
Posted July 24, 2011 - 06:35 PM
She is going to need some paint but im not going to paint it until i can sandblast it and completly tear it down and do nut and bolt restoration
#4 EricFromPa ONLINE
EricFromPa
  • 3,965 Thanks
  • 3,239 posts
Posted July 24, 2011 - 06:42 PM
That looks identical to my 127 condition wise when I picked it up.They are great machines.
After I dumped $400 into mine rebuilding the engine,PTO,wiring and paint mine looks like a new one.I have yet to fire it up after a complete rebuild but it should last another 40 or so years.I'm having trouble locating 30 weight oil for in her.There isn't a quart to be found in a 15 mile radius of me.Plenty of 10-30,10-40 oil.10-30 is to thin to run in the summer.I don't want to chance blowing it up because of thin oil.
Mine has a fresh .010 over block,fresh .010 piston and rings,new crank and std rod with new shims and gasket kit for the block and rebuilt carb.Small block chevy points conversion with Accel 1.4 OHM GM racing coil with internal resistor.She should run pretty strong after I get her broke in.
#5 Rocking416 OFFLINE
Rocking416
  • 76 Thanks
  • 191 posts
Posted July 24, 2011 - 07:07 PM
I love this machine i need a seat and a front grill The engine has not ran in years and has a tapping sound i am concerned about but i think it may just be the lifters i will see what some seafoam will free them up
#6 cubcadet107 OFFLINE
cubcadet107
  • 10 Thanks
  • 36 posts
Posted July 24, 2011 - 07:10 PM
I just got done cutting the grass with my cub cadet 107. They are nice machine.
#7 ad356 OFFLINE
ad356
  • 9 Thanks
  • 160 posts
Posted July 25, 2011 - 09:41 AM
trading a cheaply built bic lighter mtd ridding lawnmower for a solid, cast iron miniature farm tractor IH isnt a bad deal at all. the mtd will be resigned to the junk yard and the cub cadet will still be going
#8 Rocking416 OFFLINE
Rocking416
  • 76 Thanks
  • 191 posts
Posted July 25, 2011 - 06:24 PM
I agree with that She has a taping sound to the motor tho i put some seafoam in the oil hope it clears up or im going to have to tear into the engine again
