Bolens Power Ho Engine Model, need help.
3 replies to this topic
#1 wheelhorse2 OFFLINE
wheelhorse2
  • 4 Thanks
  • 22 posts
Posted July 22, 2011 - 09:45 PM
I have an old Bolens Power Ho tractor, it's the Deluxe version, so in the manual it says it has a 2 1/2 hp Briggs. My question is, what model Briggs came with the tractor, i cant tell what the tag says, it looks like it says 8R6, but i cant tell for sure, i need help! Thanks.:confuse::anyone:
#2 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 22, 2011 - 10:31 PM
that engine would be 2 1/2 hp, it could also be 2 3/4 hp, depending on where the high rpm is set. You'll need to try and keep that engine as those tractors require a gear reduced motor, and putting on a non reduced one will make it a rocket if the motor dont die from the sudden launch.
#3 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 4,007 Thanks
  • 2,485 posts
Posted July 23, 2011 - 09:19 AM
1949 - Model 12B
1950 - Models 12B & 12BB
1951-1953 Model 12BB
All the above Power Ho's used the B&S Model # 8R6 Type # 905899 engine rated at 2-1/2 hp.
There is a website where you can learn the date of manufacture of the engine, if you can read the serial #.
  • Bolens 1000 said thank you
#4 david b OFFLINE
david b
  • 1 Thanks
  • 8 posts
Posted July 24, 2011 - 02:26 PM
theyt come out with the bolens power ho deluxe in 1952.
