H16 Restore
104 replies to this topic
#16 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted July 31, 2011 - 12:28 AM
Well Im just about ready to start painting :bounce:can anybody tell me the colors for the H16? The black looks pretty basic and the white looks more like a cream color? I have desided to spray all parts with my spray gun. and I think I will get paint prices from Napa and Scherwin Williams. any thoughts on how much paint I will need?
#17 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 31, 2011 - 08:14 AM
I believe you will only need about 1 qt of white ( you will get about 2 coats on with it)
You can probably get 2 coats of black with 1 qt as well.
Since you will be adding reducer and hardener you will actually have more than 1 qt when you mix it.
On the Bolens I have restored so far, I have never used more than 1 qt for either the frame or body/hood and I got 2 coats on
The black is just a basic color,The white used on the H16 was a cream color. For the white I'd go to napa and ask to see their color charts as they have a pretty good match for the Bolens colors. Just take a sample piece if you have one and match it up.
#18 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted August 03, 2011 - 09:10 PM
OK so I dident fix the tranny leak.
It had one loose bolt and one missing but that was not the problem, so I pulled the tranny apart and found this inside on the bottom.
Anyone know what it is and where it goes?? Also if I take the gears out of the cover side do they have to go back the same way?
Edited by MH81, August 03, 2011 - 09:40 PM.
#19 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted August 04, 2011 - 06:18 AM
Only thing I can think of is its part of a thrust race for the thrust bearings.
#20 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted August 07, 2011 - 03:15 PM
I made a gasket for the tranny and put it back together last night. According to the manual all of the parts were in place. The thrust bearings are alot thicker than the peice that I found in the bottom of the tranny, the peice I found was paper thin. I am missing part#21 a shim. If anyone knows the dementions of this shim or where I can purchase one I would appriciate some info.
#21 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted August 07, 2011 - 07:36 PM
There were different size shims that were available..... I believe they came in .005, .010 and maybe .020
You may want to check one of our site sponsors and see if they have what you need
#22 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 555 Thanks
  • 1781 posts
Posted August 07, 2011 - 09:29 PM
Project Looking Good and the Buck does also, He will be Tasty
#23 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted August 07, 2011 - 11:24 PM
dstaggs thanks for the comp, and the buck does make the mouth water! :)
#24 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted August 07, 2011 - 11:30 PM
I will check with one of the sponsors! do you happen to know how much play is ideal between the shim and the snap ring?
#25 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted August 08, 2011 - 04:26 AM
You're doing a great job.
#26 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted August 08, 2011 - 04:53 AM
I forgot this was a hydrostatic..... I'm not sure if this shim came in different sizes or if it just came in 1 size.
#27 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted August 08, 2011 - 10:52 PM
Well I picked up a shim today and completed the tranny. :) I also picked up the paint from napa. WOW!!!!!! 2 bones for that paint. I got the hood and the two rear wheel sanded and the body work done! All thats left is the seat pan and control tower. I need to let my fingers grow back, I keep sanding them to the bone. :) I think next time I will look into another method of stripping!!!!!
#28 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted August 22, 2011 - 05:48 PM
I hope to do some painting next week if all goes well. I was looking through some of the parts that I sanded and I see a fine film of rust on alot of them. Do I need to sand all of them again? :( What do you all recomend?
#29 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted August 22, 2011 - 07:57 PM
Usually as soon as you get down to bare metal, you need to prime the parts the same day as they will rust up pretty fast.
I'd probably sand them again if you want to have a nice finish.
#30 speedyg OFFLINE
speedyg
  • 73 Thanks
  • 434 posts
Posted August 23, 2011 - 12:33 AM
Sand them again it is! :) thanks
