Briggs Twin II L-Head "Ticking" help
4 replies to this topic
#1 89YT12 OFFLINE
89YT12
  • 5 Thanks
  • 23 posts
Posted July 20, 2011 - 10:39 PM
my briggs 12.5 2cyl L head has been making that ticking noise what seems like almost forever, i remember reading its in the valves, if this is correct how or what do i do to solve this, how hard is it to do etc etc
its been doing it so long so i dont think its hurting anything as i never have had a problem with it doing this ticking for atleast 10 years now
thanks yall
#2 caseguy OFFLINE
  • 1,629 Thanks
Posted July 21, 2011 - 05:46 PM
Ticking valves can be an indicator that the valve lash adjustment is off causing the valve stem to click when it slams down onto the cam lobe. I am not familiar with your particular engine, so I can't tell you how to adjust them, but you could check the manuals section to see if there's a service manual for it there. It may also be a normal sound for that engine, some engines are just louder than others. None the less it couldn't hurt to check the clearances.
#3 89YT12 OFFLINE
89YT12
  • 5 Thanks
  • 23 posts
Posted July 21, 2011 - 10:23 PM
i got the B&S manual, im sure it will say something about it, i was mainly wanting to know if i was going in the right direction, like i said its been ticking forever i can remember when i was a young teen someone asking if it was a diesel ........
i hate to tear into something that does not need it, but i sure hate worse to hurt the engine
#4 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted July 22, 2011 - 03:07 PM
to adjust the valves on those flat twins the stems get ground. also check for any breaks on the ignition coil wires
#5 my deere OFFLINE
my deere
  • 11 posts
Posted July 31, 2011 - 05:22 PM
Before you dig in to far you should make sure that it has clean oil, good ignition(plugs and wire etc) etc. A lot of times the regular maintance is overlooked and can cause a lot of problems. Even a lot of carbon on the head can get the valves to cackle. Try some seafoam in the carb....
