314 Find!
64 replies to this topic
#1 grnspot110 ONLINE
grnspot110
  • 4,150 Thanks
  • 2,642 posts
Posted July 17, 2011 - 06:40 PM
I recently decided it was time to get out of the gear drive tractors by replacing my 71-110 & 74-112 with a 300 series tractor. A local mower shop has a 300 he took in on trade so I brought it home to test drive. Didn't like the severity of the vibration at startup & although it did a good job mowing (which it will only used for a backup mower), when I started uphill with it, it cut out some & smoked. Don't want to get into engine problems, so I don't want the 300!
A couple of weeks ago I found a good looking 314 on CL in southern KC, since I don't like driving through KC, I asked the seller if he would meet us in north KC. He agreed to meet us with the tractor, arrived on time with it, but it wouldn't start. He offered to fix any problem & deliver it to our house 85 miles away. Contacted him Thursday, he had it running & would call yesterday about bringing it up today. When he called, it wasn't running again! :confuse: Sounds like fuel line blockage to me, so I called him this morning & suggested he check the tank shut-off screen.
Hopefully that will fix the problem & I'll be the proud owner of a very nice 314 in a few days! ~~ grnspot
#2 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted July 17, 2011 - 06:46 PM
Hope everything works out .We'll keep our fingers crossed for you , Al
#3 MH81 OFFLINE
Posted July 17, 2011 - 09:08 PM
Good luck, intermittent problems like that can be a bear.
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 18, 2011 - 05:31 AM
I hope it works out for you. The older 300 series tractors are a nice machine with a strong hydro and rear axle. My 314 had a lot of problems but I am now close to the end of a refit. Be sure to check the drive shaft couplers and the motor mounts. The parts are available but are a bit pricey. Also the steering / front axle can cost a bit to refurbish. Wheel bearings, rod ends and axle bushings are common wear areas.
#5 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted July 18, 2011 - 06:22 AM
Good luck on your 314, grnspot. Hope you can get it soon.
  • Baliblaster said thank you
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 20, 2011 - 05:45 AM
Any news on the 314?
#7 grnspot110 ONLINE
grnspot110
  • 4,150 Thanks
  • 2,642 posts
Posted July 20, 2011 - 06:12 AM
Nothing yet! If I don't hear from him in the next couple of days, I'll give him a call. ~~ grnspot
#8 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted July 20, 2011 - 03:16 PM
if for some reason you dont get it and if your interested in a 318 i may be selling mine . still kinda kickin the ideere around .
#9 dth93 OFFLINE
dth93
  • 1 Thanks
  • 5 posts
Posted July 21, 2011 - 04:49 PM
any news on the 314
#10 grnspot110 ONLINE
grnspot110
  • 4,150 Thanks
  • 2,642 posts
Posted July 21, 2011 - 06:31 PM
any news on the 314
I'm going to call him tomorrow! I'll be down that way Sunday, no problem to take a trailer & meet him somewhere. ~~ grnspot
#11 denm OFFLINE
denm
  • 1 Thanks
  • 18 posts
Posted July 23, 2011 - 08:22 AM
hope it works out, really liked the 314 I had
#12 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 23, 2011 - 08:37 AM
If you do that you'll have to change your name to Gary400.
#13 grnspot110 ONLINE
grnspot110
  • 4,150 Thanks
  • 2,642 posts
Posted July 23, 2011 - 11:15 AM
I called him yesterday, said he hadn't worked on it this week. Can't really blame him, as it's been close to 100 degrees all week & he doesn't get off work until the hottest part of the day! He's supposed to work on it today & call me tonight. If it's ready, he'll meet me with it tomorrow, hope it works this time! Sounds like a fuel delivery problem. ~~ grnspot
#14 grnspot110 ONLINE
grnspot110
  • 4,150 Thanks
  • 2,642 posts
Posted July 23, 2011 - 09:15 PM
Seller called, as he said he would, told me to bring my trailer tomorrow! :D Said the gas tank had grass & trash in it. Carb. has been cleaned lines blown out, fuel pump checked & tank cleaned. I'll put an in-line filter on it when I get it home too!
Pics in a day or two! ~~ grnspot
#15 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 24, 2011 - 04:54 AM
Good News. Hopefully you will get good weather for the trip. Looking forward to the pictures.
