1975 mf16
101 replies to this topic
#91 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted July 01, 2013 - 07:23 PM
:dancingbanana:
I'm happy for ya Doug, that you got it up and going.
It sounds good. Could you make up a manifold type of thing, and fit that
muffler out on one side or the other?
Kinda like this, but your muffler laying horizontal.
  • DH1 said thank you
#92 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted July 02, 2013 - 07:37 PM
Been having trouble still trying to get this engine to run smooth and steady.
At Idle it's smooth but when you increase the throttle lever it's erratic. You can see the throttle on the carb move, vibrate when it's above idle.
If you hold the throttle with your fingers it's smooth and steady at all speeds.
I have noticed that some carbs have a spring warped around the throttle shaft that try's to close the throttle.
So I found a small low tension spring and attached it to the throttle and the engine shroud which try's to close the throttle same as the other type does.
Now it runs smooth and steady at all speeds, much better.
  • olcowhand, Texas Deere and Horse and Sawdust have said thanks
#93 Texas Deere and Horse OFFLINE
  • 15112 Thanks
  • 15570 posts
Posted July 02, 2013 - 10:34 PM
Doug, Id the shaft a little loose in the bore by chance?
#94 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted July 03, 2013 - 09:08 PM
Shaft is fairly tight, you can see the throttle vibrate, open and close when running without the spring.
With the spring it stays steady, no movement until you move the lever on the dash.
#95 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted July 03, 2013 - 09:10 PM
:dancingbanana:
 going to try to keep the original looks and have the muffler under the hood, but ???
#96 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted December 29, 2013 - 06:59 PM
Still not finished or even usable.
Time to finish this one too.
#97 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted February 15, 2015 - 06:44 PM
I had this thing running today, hasn't been run for a long time but seems to run good.
I have a MF530 Dozer blade for it and maybe tomorrow I try to mount it and use it.
  • limebuzz and KennyP have said thanks
#98 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted February 16, 2015 - 05:16 PM
I got the blade on it it's a modified MF630, should be a MF530 but it fits and works.
As you can see the tractor is in need of some parts to finish it, hood, grill, foot board extensions and a muffler. The muffler on it is just so I can use the tractor, doesn't fit under the hood, need to make one as I can't find one.
This tractor I want to take to Plowday events, mainly Dans, "Ball Hollow Plowday".
It's runs OK, has gas in it that's 1-1/2yrs old, hopefully runs better with fresh gas.
I can tell you this for snowplowing it's got more pushing power and speed than my Massey 10s and 12's do. You can feel you on a heavier, faster machine.
Edited by DH1, February 16, 2015 - 05:19 PM.
  • IamSherwood, KennyP and propane1 have said thanks
#99 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 16, 2015 - 05:34 PM
Do you have the hood and grill?
Maybe something like this?
#100 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted February 16, 2015 - 05:40 PM
I got good grill and hood and the proper exhaust fitting on the block, would like to keep the muffler under the hood like original was.
  • IamSherwood said thank you
#101 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 16, 2015 - 06:23 PM
I know you would never do it, but just don't do anything like this.
That stuff makes me soooooo mad. :wallbanging:
Bend the grill, punch a hole in the screen, and mess
it all up in 5 minutes. Simple.
#102 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted February 16, 2015 - 06:38 PM
What are you talking about I think that's AWSOME :thumbs:  :wallbanging:  :firejumper:
