1975 mf16
101 replies to this topic
#76 ckjakline ONLINE
ckjakline
  • 1185 Thanks
  • 1176 posts
Posted September 02, 2012 - 09:10 PM
just took my time and enjoyed working on the tractor for the day.
That's what the hobby is all about isn't it?
You bet it is.It's all about enjoyment of the machines.Whether it's using them or just changing a spark plug.
#77 KennyP ONLINE
  • 51098 Thanks
  • 52673 posts
Posted September 02, 2012 - 09:52 PM
Good to hear progress is being made here, especially when you enjoy doing it.
#78 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted December 04, 2012 - 09:16 PM
I can't believe I've had this thing for almost 1-1/2yr and it's still in pieces, not finished yet.
Too many dreams, projects on the go, got to pick one and finish it, I think I'll start with this one.
Time to get off my butt, the computer and do something about it.
#79 mac102004 OFFLINE
mac102004
  • 602 Thanks
  • 612 posts
Posted December 04, 2012 - 09:42 PM
That's the attidude! lol
Wish I had some free time to restore my '66 MF10.
#80 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted December 04, 2012 - 11:20 PM
I've been working on things 15 minutes at a time, Doug I feel your pain.
I'm just happy to get one running again.
#81 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted December 08, 2012 - 08:17 PM
Today I picked up a set of Front wheel weights for the 16.
I have looked for 2 - 3 yrs for cast iron weights for 8" wheels and finally I got a pair.
They weigh 35lbs each and fit the MF16 front rims nice and flush.
16-6.50x12 tire size, same rim used on MF10, 12, 14, 16.
Some MF10 and 12 came with narrow rims for the 4.00-4.80x8 tire, if you put these weights on those rims they stick out a lot.
I need to relocate the tire valve to the inside of the rim, seal up the outside valve hole and drill for the mounting bolts.
I know I know these are john deere weights but there not brand name stamped anywhere so I paint them Massey Red and no one will know.
I also picked up a while back rear wheel weights, 50lbs each, need to paint these Massey red too.
This gives me front and rear cast iron wheel weights for the MF16, these are what I call hub caps.
  • IamSherwood said thank you
#82 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted December 08, 2012 - 08:30 PM
Congrats on the 8" wheel weights! great find. You don't see the fronts come up for sale to often.
And you might have time, hurry up and get some red on those before someone see's them :biting_nails:
#83 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 09, 2012 - 06:06 AM
Nice Doug. Are you going to E-tank them, or sand blast them, so that yellow is gone for good?
Yes, they certainly will look good as hub caps.
We talked about front weights about a year ago, and I did try my MF8 rear weights on the MF16 front.
They will fit, if they get bored out in the back, to fit over the dust cap.
#84 KennyP ONLINE
  • 51098 Thanks
  • 52673 posts
Posted December 09, 2012 - 07:14 AM
Cool weights, Doug. Could you put a valve stem in the front hole backwards to plug it and still have clearance for the weight?
#85 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted December 09, 2012 - 08:27 AM
Can do that or paint stripper and wire wheel them, one way or another the yellow has got to go.
Never thought of doing that and I think it would work too.
#86 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted December 09, 2012 - 10:20 AM
Some schrader valves will release under pressure that direction (the ones you can fill with the air nozzle instead of the chuck)
The spring pressure is all that hold it closed that way, the air pressure behind the valve is what helps hold it closed.
That said, I'm not sure that 10 lbs would cause it to open, but it may have a slow leak.
Another option, cut the old stem off so it won't mess with the weights and then drill the hole on the other side and use a tube. The remains of the stem will hold the tube back from the hole and the tube is (IMHO) a plus anyways.
#87 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted December 09, 2012 - 10:35 AM
Never thought of that either, I was originally just going to drill a new hole and weld the old one up.
Plan on using V61 tire with a tube.
#88 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted June 17, 2013 - 10:07 PM
Back at working on this thing again, been apart so long having trouble remembering how it goes back together, but it's getting there.
I want to hear it run again and use it for what they are made for.
Muffler looks like is going to be the big problem now will see what I can do with it.
  • olcowhand and Texas Deere and Horse have said thanks
#89 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted July 01, 2013 - 03:36 PM
Finally today I got it working, motors in runs and the 3 point works.
The muffler is a nice big quiet one but will never fit under the hood, have to find something else.
Still lots of things to do on this tractor but I now see the end is near.
And a big thanks to Kenny for letting me use his plow for the test.
#90 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted July 01, 2013 - 04:07 PM
She sounds great Doug!  Looking good!
