welding question
19 replies to this topic
#16 Texas Deere and Horse OFFLINE
  • 14,859 Thanks
  • 15,510 posts
Posted July 19, 2011 - 07:25 PM
Also Peening the weld as soon as you stop each weld with a chipping hammer will relieve the stress in the weld, helping it to not crack out on you. The slower you cool it down the better it will hold up.
  • caseguy and ncb have said thanks
#17 Rick Brumback OFFLINE
Rick Brumback
  • 19 Thanks
  • 124 posts
Posted July 19, 2011 - 08:27 PM
Nope.You need a stick{arc} welder and cast iron rods If memory serves me,the cast MUST be heated to around 500 degrees.I would recommend a welding shop.
#18 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 20, 2011 - 06:01 AM
Sounds pretty tricky and with a flywheel the results of a failure could be spectacular not to mention dangerous. With the screen I would just try the JBweld. If that failed then you would just have the screen flapping. If a welded flywheel decides to crack in half then that would be disastrous.
#19 plab OFFLINE
  • 8 Thanks
  • 20 posts
Posted July 24, 2011 - 02:27 PM
a few years ago I bought a older soap stone(hearthstone)wood stove .these stove have a cast iron interior. some of the plates were cracked and are quite exspensive. So i decided to weld what I could . I did the heat with thing with oxy/acc , let it cool down slowly with the torch.
well this will be heating season four on those plates. I'm no pro welder by any means but I like to try to fix things when I can
welding was hard to get it to look nice but its holding up. IMO I'd try it . but use a stick welder
#20 mjodrey OFFLINE
  • 2,356 Thanks
Posted September 07, 2011 - 02:36 PM
mova211,welcome to the forum.
Glad to have you with us.
